Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
                  Paul, yes, I think it's the ESC or some other power related issue on the vehicle.  There are many things that could cause a spike on the pwm signal pin .. for example, are the ground wires from the ESC connected to the pixhawk's top rail (on the back of the pixhawk)?  The issue is very unlikely to be in the ArduPilot software.
                  • "for example, are the ground wires from the ESC connected to the pixhawk's top rail"
                    Randy, I have all the esc GND wires at the top of the Pixhawk and the signal wires at the bottom.
                    I sense that you have more options for this problem.
                    Can you please suggest some more possibilities?
  • Test ......................
  • Didnt find correct place to post log related to 3.4-rc1
    I am having serious issues with my copter, in the way that it does fly for a short period and then just descends abruptly hitting the ground. As soon as I see it descending (usually i'm flying at 2~3m above ground because I'm trying to find the cause of this problem) I switch to stabilize and cut throttle to avoid major damage.
    At first I thought this is was a temperature related issue, but now I dont think so.
    I saw a log that contained barometer error in the exact moment the temperature rised to 70º degree inside the frame (it's an waterproof one) but now logs dont even show any error, the copter just falls to the ground...
    Anyone willing to help me figure this out ?
    2016-05-30 15-01-15.bin
    2016-05-30 15-34-03.bin
    https://storage.ning.com/topology/rest/1.0/file/get/3702248929?profile=original
  • Hi I was wondering if anyone could take a look at this log and help me out with a flyaway problem in loiter mode. Flies well in stabilize, but when I enter loiter, it changes roll to max within a second or so and flies into a tree unless I switch to stabilize. There are some vibrations but I don't think this caused it as my other two MR's are doing the same thing in loiter.
    copter 3.3.3
    6s, 380kv 15" props, 880mm 6lbs
    Could it be the momentary gps glitch? I wasn't able to run telemetry, but here's the .bin log of the last crash where I enter loiter once, and have to go back out immediately as it seemed to take off. Then I tried it once more and it took off into a tree before I could switch to stabilize. Luckily it escaped undamaged. It shows a radio loss as the antenna broke off when it hit the tree. Or could the issue be caused by these settings I had previously made in attached photo?
    Any assistance and I would be most appreciative, thanks!
    1.BIN
    • Don't look a gps glich, only look a vibe glich the two times that you switched to Loiter but I don't know why, your compass and acc all are well calibrated?
