Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
  • Is vibration spikes fixed at RC4?
  • Hi Randy,
    I just saw RC4 is out, thanks for that.
    Any chance following issue gets fixed in RC5 ?
    https://github.com/diydrones/ardupilot/issues/1713
    • Maybe someone should add a note in the wiki the DO_CHANGE_SPEED command does not work as expected until now ...
  • Tried loading the Beta version today but it failed with error: could not download the hexfile.
    Trying again and the comport on my PC show up for a second when I connect the Pixhawk.
    On the Pixhawk the LED is solid  white and this seems not normal.
    Feels like the board not activates the comport.
    Suggestions? corrupt bootloader?
    • Found the problem, for some rason the sd card had to be formated. Did the firmware upload set the sd card as unformatted?
        Goran,
        The firmware shouldn't have caused that to happen although AC3.3 does have some extra logic to automatically format the card if it finds it's unusable for some reason.  This has the effect of clearing all your log files but it doesn't get rid of parameters.
        • OK thanks, but the only way to access the pix with usb was to take the card out and format it in my PC.
          Anyway it is fixed now.
  • Part of this is cross posted from here http://diydrones.com/profiles/blogs/u-blox-m8n-ground-planes-antenn...
    I was flying on the shores of Lake Huron in Michigan today; absolutely gorgeous weather and flying conditions.
    Here's the flying condition:
     Takeoff launch position was about 3m from the edge of a cliff ~20 meters higher than the water.  Is it possible the difference in altitude from the launch position and the water is playing tricks on the baro and EKF/GPS?
    How do scenarios like this affect the barometer?  Once the copter takes off, does the barometer "see" this altitude change? Would lidar be a good addition to have in order to get a true altitude reading once launching from the cliffs? Today was a practice flight for a trip this summer to PIctured Rocks on Lake Superior in da U.P. where I want to get some nice video of from above the water. I find it difficult to judge how far above the water the copter is and wonder if the barometer provides an accurate altitude so my equipment doesn't end up in the drink.
    • Air pressure will not be different above (at your take off point) or beyond the cliff. Thus your barometer should read the same value and should not register any altitude difference once you go over the cliff and expose your copter to 20m altitude.
      Air pressure value changes from the mean sea level. Where you flew your copter was the same vertical distance from this sea level.
      GPS vertical data cannot be trusted at this situation either. So the only way to register the altitude difference in your case would be using some type of distance sensor (ultrasonic, IR etc.)
      • Thanks, I'm looking into LidarLite.
        I still don't understand how there can be such drastic altitude errors when using RTL/Land (by switch or Auto mission) in only a few minutes of flying. It happens at my home, field and yesterday at the lake and two different copters, one using Pixhawk, the other AUAV-X2.
