Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
      Hi Henri,
      Sorry for the slow reply. I have tried a couple times but couldn't do it as I only had my phone.
      This is the process I use when starting tuning a large copter. First up set these parameters
      MOT_THST_BAT_MAX,number of cells x 4.2
      MOT_THST_BAT_MIN, number of cells x 3.5
      MOT_THST_EXPO,0.75
      and
      THR_MID,300
      Then set the control loop parameters to their defaults.
      In stabilize slowly increase your throttle until the copter starts to lift of the ground. Listen for any sign of oscillation and if you hear it be ready to shut down the throttle immediately.
      One of the things I find is if you are hovering lower than 30% then you will tend to have trouble with autotune. If you are hovering at a very low throttle position then add weight to get your copter up into the 30% to 40% range. If you are above that then no problems.
      Once you can take off safely then you can start testing small roll and pitch inputs. Keep the copter low so you don't do too much damage if you need to shut it down. I will tend to do this at around 0.5 m.
      If you find the copter reasonably safe then you can increase height to say 5m and increase the roll and pitch inputs.
      If you find the copter is a little wobbly (slow wobbles about as fast as you can say wobble wobble wobble) then increase the Rate D terms (you can use the slider set to go from 0.004 to 0.008). Just make sure you don't increase it to the point you get oscillations.
      If you get oscillations then you may have a flexible frame or something like a gimbal that can move. If you are lucky you will be able to just reduce Rate D. I haven't seen anything that oscillates on the stock PID settings.
      This should get you flying. Then you can build up your roll and pitch inputs (30 degrees) to the point where you feel comfortable running auto tune. If you don't feel comfortable you may need to do a manual tune before you can run Autotune.
      Hope that helps and sorry for the delay!!!!
      • Hi leonardthall.
        Thank you very much for your help. Ecalc software "said" that hovering should be around 45 to 48% throttle. (8S 10A) giving a possible 4 to 6 minutes flight. So hopefully should go ok. I'll follow your directions.
        On a different subject:
        Still with 3.3 RC5:
        Following a successful autotune on a 1 meter (axis to axis) hexacopter,  storing values after completion of auto tune indicated on mission planner (one axis at a time). everything looked great. Did first roll then pitch and finally yaw. This last one took really a long time..
        Anyway few days later wanted to take off and aircraft was really jerky, short wobbles, and it was really hard to see if it was in the pitch or roll axis. Diminishing the D value a bit at a time did sort of "calm down" the beast but I couldn't work out why it did change so much. (From a fantastically stable aircraft in the air just at the end of auto tune to a nervous wild jerky beast)!
        Just thought I let you know as something changed in between without clear reason.
        Cheers
        Henri
    • The default PID's are normally pretty acceptable to get you in the air on your maiden.  Have you experienced any problems with the settings?
      • 3702705392?profile=originalWell it depends which "default" one selects from mission planner.
        I guess PID are very different depending upon weight motors prop size and shapes etc...
        So I would have like to get some "possibly working PID" for the model I did mentioned. (Heavy H shape aircraft).
        • What is the default setting and wich to choose for Tarot FY690S ?
          Any help on this are welcome ;-)
        • You shouldn't need to touch those when starting out.
          The tunable parameters for flight are on the "Extended Tuning" tab.  Their default value should get you a reasonably stable take off. You may need to slightly tweak to keep it stable, but it shouldn't be far off
          The challenge with sharing PID's is they're based on a myriad of factors which don't typically replicate when DIY'ing a model.  In your case, you are flying a very large and heavy craft with an indeterminant frame, motor, ESC and weight balance combination.  If I don't have all of those the same as yours, my PID's -- particularly having been tuned and therefore very specific to my craft -- are likely to be a risky proposition.
          TBH, this quad is a significant investment and I'd caution against running beta firmware before you've tested with a stable release.
  • Dont know if this belong here....i have this hex with rc5. Almost tried all 3.3 rc's, but hasnt done much flying. Just waiting for release.
    Anyway, today i was trying to calibrate a attopilot and locked the hex down to prevent lift. In stabilize mode the pixhawk throttled up ALOT by itself after i gave just around 5-10%, like if i have raised throttle slowly to nearly full.  Throttling down again was possible. Tried several times and it was the same. In alt hold the throttling was normal. Thought of trying to fly in stab mode to see if it happened then, but found it to risky.
    Is there a parameter that can cause this? Have weighted it down before many times and it wasnt like this, throttle was normal.
    All is calibrated. transmitter in missionplanner, esc's, compass, accel..
    Bjoern
    • I think I had same and I concluded that program feeds input to motors, does not see response from a barometers and feeds even more input to motors to increase lift. Is it a logical assumption?
      I tried to fly mine in stabilize mode and it did not get anywhere, if that matters.
      • eh, maybe if it had a plan to go somewhere on its own :) dont think it knew i put rocks on its feet, haha
        Maybe if there was a mission and it should reach a certain height, but not in stab mode, i cant imagine...
        You mean you couldnt take off?
        • sorry, bad choice of words. did not get anywhere = it means it did fly fine and did not fly away from me.
          stabilize mode worked fine. no issues. I have different problems - failsafe RTL, controls invert in super simple mode, etc.
          I posted logs here about them.
