Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
      • The messages at the Ground Stations (like Mission Planner and APM Planner) are not pre-recorded wav files but generated by the TTS engines from the computer operating systems.
        The best way to list all the messages from the source code is to do like I did awhile ago for 3.2.1 is to grep PSTR(" and list all the messages including punctuation and capitalization inside the quotes.
        • Well, it is a problem a bit as on Taranis it looks for a code of the message and then plays a file with same filename as a code of the message. OK, I will try to figure it out.
          • The code on the Teensy has to be redone to cope with the new messages
      • Would you be so kind as to post your serial port settings that work for you with 3.3? Thx
    • T3
      Thanks a lot Randy and all devs involved!
  • in my opinion, guys, not having reliable landing detection is a big problem for experienced and early adopters alike. Designing and building up craft for professional/research use and passing these large fliers onto pros is a big responsibility. Having to worry about them flying in Loiter (which will be a common practice for survey/imaging pros), then landing and having the rig flip on its side as they try to disarm, destroying expensive props at best and causing bodily or physical damage at worst, is enough to keep a guy awake at night.
    Can we do better than "just switch to Stabilize"? My intention is to be constructive, here, and as an engineer, I'm happy to dive into code to help try out some potential patches.
    Because for me, I can't reasonably write in a technical manual that they must get to Stabilize before landing to prevent a failure of landing detection for multiple reasons. First and foremost, we can't assume throttle parity. they might have throttle quite low in Loiter to allow for descent, so the same position might correlate to practically no thrust and we crash to the ground, or the opposite with higher throttle, and we have a perceived flyaway. Secondarily, giving a pro with enough to worry about as it is on the job shouldn't have to concern themselves with always flipping to an essentially manual flight mode just to get the craft on the ground and review imagery.
    I've personally had at least two occurrences like this, one on a big hex spinning 16" props (running 3.2.1) that scared the daylights out of me and just a few days ago on a small Y6 (on 3.3 rc10). So it doesn't seem to discriminate for frame size or AUW. For me one of the triggers seems to be adjusting position while close to ground before landing, which is very common in even moderate wind to make sure you have a nice balanced landing, especially when you need to land on a particular spot due to topographical variation.
    So - I'm looking for guidance from developers and community alike. How can we all work together to do better?
