Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
Hi Julian,
Your log looks ok, good vibrations, but it might be worth dropping your ACCEL_Z_P and ACCEL_Z_I values by 50% and see how that feels.
If it doesn't fix the problem put the values back and let us know.
Sorry I couldn't be more help!!
Julian,
I'm having a hard time finding the place in the log that shows an issue. The desired altitude and actual altitude seem to be sticking pretty well together (see first graph below. maybe 20cm of movement?).
The desired and actual climb rate also look pretty good as well.
When my copter is loosing altitude, stationary or at the end of a high speed run, the altitude as displayed on the OSD is constant. If the copter's sensors think it has not lost altitude how can the log accurately reflect the true change in altitude?
The log may show 20cm though the actually change might be much more.
From my tuning experience on a Naze32, the alt hold tuning had 3 different parameters: P For baro vs accelerometer bias, I for voltage change over time and D for reaction force. You just increase the P and D to the point where the aircraft started osilating and then back then off a bit.
Are there equivalents in Arducopter?
Looks like this is a bad example log for my problem...
If I fly very slow or just stand still the copter hold the altitude pretty well, but if I fly faster it dramatically looses altitude and I have to switch to stabilize to prevent a crash.
I think this log shows the problem better (from 9min): https://drive.google.com/file/d/0B2P7_aBCn5tRN3JWaFZFUVNyam8/view?u...
Ok, so this is a "known issue" called "altitude loss after fast forward flight" in all versions of Copter including AC3.3 and is not an issue we were attempting to resolve with AC3.3. In this way it's a bit off topic but in any case, it's the barometer being upset by pressure differences caused by wind hitting the frame at different angles.
This is quite visible in the log. When the vehicle's Pitch angle (yellow, scale on right) goes to 40 (leaning back) the barometer altitude (dark blue, scale on left) climbs from 6.7m to 13.5m (a nearly 7m change). the 7m baro climb drags the inertial nav altitude up so it thinks it's climbing and so the vehicle descends to compensate.
There have been discussions on software solutions but at heart, it's a frame issue. A frame that's built with the baro effect in mind does not suffer from this effect. An IRIS for example does not suffer from this because it has somewhat balanced air holes on the top and bottom. A Solo does suffer from the problem because it's a closed top with a large hole on the bottom for the gimbal.
Randy please enlighten us!
http://diydrones.com/forum/topics/effects-of-frame-design-on-barome...
Are there already some good ones started or is going to be new ground for most of us?
Randy, if this is specific to pressure reading in AltHold, would this suggest that we shouldn't see this same issue with PosHold (due to its altitude being determined from GPS coordinates instead of pressure)? The reason I ask, is (and I know this isn't exactly on topic, but since the pressure phenomenon has been present in all versions historically) , is that I see the altitude drop (in 3.2.1) when moving forwards at speed (so at 45deg forward pitch attitude) when I am flying in AltHold mode. then upon a quick stop, the copter climbs to the initial altitude and holds there. Does this suggest that in PosHold, we are still using the barometer for altitude?
Paul,
I haven't seen your logs but what you're describing is likely a separate issue related to the pilot asking for a lean angle that the vehicle physically can't attain while also maintaining altitude. An enhancement request to prioritise altitude over lean angle is here on the to-do list.
Most vehicle's simply don't have the power to lean over at 45 degrees and maintain their altitude. I've been considering reducing the ANGLE_MAX default to 35deg or 30degrees but haven't yet.
In reality it's more like 1 to 2 meters. When descending it's slow, but when it's ascending it goes pretty hard. Sure doesn't look right. I'll shoot a little video with another log. I'm also taking up a 1300mm X8 with the same pixhack. See how that goes.
213
214
215
216
217
of 449 Next
