Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
could this be the issue with the telemetry?
Austin,
For the GPS issue, as part of setting up the optical flow sensor did you set the EKF_GPS_TYPE parameter? If yes, maybe setting it back to "0" might get it working again.
I had changed the EKF_GPS_TYPE parameter back to 0. It failed to even show stats about the GPS, i.e. Sats, hdop, etc.... After that didn't work, I actually went one step further and used a beta param file I saved from before I configured the OF, when the GPS was working, and reloaded that. No dice. Even reflashing the firmware to the same beta firmware didn't help. The problem only resolved when I reflashed to 3.2.1. I will see if I can get the logs for you.
same thing happens to me when i use the 3.3 beta on PX4FMU + PX4IO. it didnt see the attached GPS but resolved when i use 3.2.1 firmware.
Way OT sorry. Couldn't resit. Still hoping for 'boat mode'.
"boat mode" coming soon! It will calibrate copter (and Solo gimbal) on moving vehicle. Dynamic home location (for moving platform) and GPS position-hold loiter optionally replaced by alt-hold, to ensure that the vehicle doesn't zoom "backwards" trying to hold a static position while you're on a moving vessel.
Although I am sure you probably are aware of this already, here are some guys who have already implemented "Boat Mode" - http://mikrokopter.altigator.com/boat-mode-take-off-from-a-boat-n-3...
From what I can tell it works basically like this...
1. You arm you bird on a nice level surface on the mainland.
2. You hop on your boat, switch to "boat mode" - which loads the last values of the gyros, i.e. the ones you got in step 1.
3. You take off in Alt-hold - for obvious reasons. Switch to loiter up in the air if you want.
Simple and effective. This should be easy for the devs to implement.
Hi Erik and Terry,
We have the solution already and it will let the pilot take off from a boat just like on land. There are a couple of key people that need to clean up the work. Time is always our biggest challenge!!
Winter is coming... so boat mode is not in high demand, but I'm still curious.
