Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
  • Updated from 3.3-rc1 to rc9 yesterday on a TBS Discovery Pro.
    Autotune results were fantastic, the end result was a lot less twitchy than those on previous versions. Very smooth flying.
    In addition, landings used to be very bouncy and the landing detector wouldn't trigger unless I switched from Loiter/Poshold to Stabilise, where I then was able to throttle down a lot more.
    Now the landings are much smoother - it still takes around two seconds for the landing detector to trigger while landing with Loiter/Poshold, but it's a lot better than before. Very happy about this.
    I did observe something strange, namely that the GPS HDOP value was at 99, despite having over 13 satellites. The position in the map looked stable as well, so I set "GPS_HDOP_GOOD" to 10000 and took off. It flew and hovered fine, so I'm not sure if:
    a) The GPS (CSGShop u-blox NEO-M8N) is defective
    b) GPS reception was bad after all
    c) It's maybe a bug introduced by a change in rc7 that affected HDOP/PDOP reporting
    Log attached.
    2015-08-27 11-50-45.bin
    https://storage.ning.com/topology/rest/1.0/file/get/3702080835?profile=original
      Mark,
      This can be caused by the configuration messages from the flight controller to the GPS not getting through.  It may be a one-time thing or it may be because the GPS cable has been damaged.
      This weakness has been there, as you suspected, since we changed the hdop value in -rc8.
      It's possible to add a check into the driver and/or it possible to update the GPS configuration using u-center to specify the dop message is required so that it's sent even without the flight controller asking for it.
    AC3.3-rc10 is available for beta testing.  I've updated the main section with the changes.
    The changes vs –rc9 are mostly of bug fixes and safety improvements.  This is hopefully the last release candidate before the official Copter-3.3 release.
    The new EKF compass variance pre-arm check (3a) may require another release candidate because if the EKF stops using the compass there’s currently no way for it to recovery without rebooting the flight controller.  Solo-master has a solution for this that we may need to import if too many people find they can never get past the “EKF compass variance” pre-arm check but let's see!
    • Randy,
      I have a concern about the rc10 change mentioned in item 3e of your updated OP.  5 meters seems high for a fixed value.  I frequently launch from my back yard where I have trees, shrubs, and house on 4 sides with a 5 or 6 meter square open region.  I generally set the final return to launch altitude to a safe height above the trees in case the GPS error is higher than normal.  Then I can command the land when I am ready to control it for safety.  I'm usually able to guide the landing and I usually fly with telemetry so I should be aware if it decides to land where it shouldn't, but if I'm not paying close attention, a failsafe landing 5 meters from home will cause a crash.  I believe I have WPNAV_RADIUS set to 2 meters (Is that the default?) but I really don't want it to land at all, even if the failsafe is triggered directly above home.  At the very least, I need less than 5 meters offset.
      Would it be better to use the smaller of WPNAV_RADIUS and the hard coded number rather than just the hard coded number?  It would also be great to have the option of not choosing land at all as the action!  Especially if the final altitude is not 0.
      In fact, isn't the goal of this cut-off radius just to avoid the climb to RTL altitude and the extra risk that involves?  Wouldn't it be best then to just implement it that way?  If within the WPNAV_RADIUS, just skip the climb and perform the rest of the normal failsafe RTL action?
      Thoughts?
      --Brad
        There are a number of parameters listed on the RTL flight mode wiki page that may help.  So for example, to stop the vehicle from  descending during the land phase of RTL, set RTL_ALT_FINAL to a number > 0.  like 10m and it will stay up there.
        I think everyone understands, but just in case, the failsafe radius of 5m is only used to make the decision whether the vehicle should RTL (as the failsafe parameter specifies) or whether it should instead LAND.  So if the vehicle is within 5m of home when the failsafe happens, it will trigger a LAND instead of an RTL.  If an RTL happens, it will still attempt to land at the takeoff location.
        The feedback I've received on the previous 2m radius (from a few people) was that it was too small.  There's some discussion of a more complicated decision involving altitude and distance from home but sadly that will need to wait for Copter-3.4.
        I think 5m (or 15feet) is really quite a short distance but I must admit when Luis and I discussed it I thought to myself it was perhaps too large.  How about 3m or 4m?  I'm not keen on using WPNAV_RADIUS because I think most people will not expect this parameter to affect the failsafe behaviour so I'd prefer a hardcoded distance if we can agree on one.
        • Use of WPNAV_RADIUS does make sense to me, especially since the other WPNAV_ parameters control the return speed, etc.   But I think the more important issue is *why* is land being performed at all if RTL is the selected failsafe action?  As you mention, land may not even be configured as a part of RTL if RTL_ALT_FINAL is not 0.  So if it's not zero, why land just because the failsafe happened to occur within a 5m radius of home?  Shouldn't we be going to RTL_ALT_FINAL instead?
          I'm guessing the motivation for land if inside WPNAV_RADIUS was just an easy way to avoid wasting power climbing to RTL_ALT only to decend and land again later (in the default case where RTL_ALT_FINAL=0)
          I see this as a safty issue.  If RTL_ALT_FINAL is greater than 0, it may be because it's pilot control is the only safe way to land.  If so, failsafe should not land, no matter where it happens to be when failsafe kicks in.
          --Brad
      • Hi Brad,
        I was discussing this issue of the radius with Randy, and the 2m seems somewhat "short" because of the errors associated with positioning,  read "GPS positioning radius", which would result in never being "inside" that circle.
        With a larger fixed diameter the possibility of being inside the radius increases, and you have the ability of repositioning the vehicle while it is landing (LAND_REPOSITION=1).
        Other option would be to use the GPS horizontal error as a factor, but that would vary too much to be reliable.
        Even yesterday with RC9 I had one of these events happen to me, while I had the quad in front of me at arm length,  and at head height, when the RTL from the battery failsafe kicked in and the quad shot to the sky (15m), although it had been armed from aprox. the same position I was flying, but the GPS error had it  outside the 2m radius...And believe me that an overpowered 330 quad can scare you if it jumps right in front of you from head height to 15m....
        • Isn't the WPNAV_RADIUS parameter expected to be used for exactly this purpose?  To avoid wasting time hunting for an exact position?  I assume that's why it used to be the cut-off between the two behaviors.  The problem was caused when someone had that parameter set very high and a landing was performed in an unsafe area.  It seemed very reasonable to me to use that parameter for this purpose.
          I don't think a 2 meter radius would result in never being inside the circle unless the EKF position estimate is drifting around very quickly!
          But as I said, I may not want unguided landings at all.  I'd rather that LAND is not even a possible failsafe action if I have configured RTL. (except, perhaps when there is no longer enough voltage/throttle headroom to fly reliably).  I've already specified the failsafe action as RTL without a full landing by specifying a non-zero final altitude.
          It seems to me that instead of land, we just want to avoid the climb to RTL altitude when we are already home.  And it seems to me that already home may as well be specified the same way as all the other waypoints with WPNAV_RADIUS.
          --Brad
    • I just upgraded from -rc9 to -rc10 and noticed that my motors no longer spun up when armed. I had to change the MOT_SPIN_ARMED parameter to 75 from the default 70 to get them to spin as they did before. I hope this is the correct method.
      • Did you try doing a esc calibration after the update and before you changed you mot_spin?
DIY Robocars via Twitter
RT @a1k0n: Did I get rid of hand-tuned parameters? Yes. Am I still hand-tuning more parameters? Also yes. I have a few knobs to address the…
1 hour ago
RT @a1k0n: I'm not going to spoil it, but (after charging the battery) this works way better than it has any right to. The car is now faste…
1 hour ago
7 hours ago
Saturday
Saturday
Saturday
Friday
Thursday
Sep 11
Sep 10
Sep 10
Sep 10
Aug 28
Aug 24
Jul 4
Jul 4
