Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
here:
http://diydrones.com/forum/topics/copter-3-3-beta-testing?commentId...
We won't fix the dual GPS issue in AC3.3 I'm afraid. That will be an AC3.4 improvement. I'm going to change the wiki to say that we don't recommend a dual GPS solution for copters until this enhancement is in.
Kurt,
I've heard of people pulling one of the wires from the GPS to stop the auto configuration but so far I haven't heard why that's being done. If it's because you're piping the GPS's data to another source and that other source requires NMEA then that's a reasonable idea although I worry that the 38k serial link might run out of bandwidth to support both types of messages.
By removing the TX wire from the APM/Hawk [the RX on the GPS] the configuration is not updated on the GPS so when people make custom configurations on their GPS modules from say U-Center it is not overwritten by ArduPilot on bootup.
@Kurt, Craig, if you could raise an enhancement request in the issues list that might be the best place to discuss.
I've just had a problem with there being 4 more images than cam trigger events. (224 images, 240 trigger events) on RC11 during an auto mission. Previously I've only ever had more trigger events than images when the camera couldn't keep up, but it can easily keep up with the rate it was being triggered here.
Does anyone know what could be going on?
There's a log over on the thread about it.
http://diydrones.com/forum/topics/cam-msgs-and-files-discrepancy
I've just found some more weird behaviour with this log while using the geo ref tool. Using a time offset then generating the location kml, the flight path gets cut off about 40% of the way into the flight, then jumps to the end position, and also has a large gap in the image locations, however using the 'create kml + gpx' option in MP, the full flight path is displayed correctly. This makes me think there's something wrong going on with the geo-ref tool, or else my log is somehow seriously broken.
There are images showing this on my other thread. http://diydrones.com/forum/topics/cam-msgs-and-files-discrepancy
Also my geo-ref tool doesn't give me any options to change the field numbers like it has in previous versions (and like in your screenshot Shaun).
Edit: updated MP from 1.3.32 to 1.3.32.1 (beta updates) and now I can use the time offset without it cutting the log off half way. Still has the non-matching number of trigger events to images though.
Thanks for looking Randy. Sorry it was 224 images, 220 trigger events... was a typo in the last post. The card is a fast sandisk ultra 8gb which benchmarks as having a good write speed. This log is only 10mb for a 15 minute flight and I don't have any additional logging turned on, so I'm pretty sure it's not an issue with the card not being able to keep up. If there's a way to tell for sure whether this is the issue though I would like to know.
I just want to make sure I can avoid this happening in future since I'll lose precision if I can only use the offset geo ref method (not to mention the pain of trying to get the offset right) rather than being able to use the cam trigger events.
Hmm yeah it is using a GentLED to trigger. Wonder if it somehow double triggered via IR, but it's all set to manual focus & no review, so it triggers pretty much instantly when it gets the signal and is good to go again quickly. I've taped the LED to the IR window and covered it over so there's no external light that can get in and mess with things. I never had any issues with image #/log mismatches on 3.2 with this same setup, so I'm wondering if it might be something else.
I haven't been able to geotag images for a while, on 3.2 or 3.3. I can't even find any cam_trigg messages in the log. I managed to tag in Mission Planner once recently using time difference but it came out a bit odd (registered all the photo's as a single line). Pix4D doesn't recognise the logs either. I use a relay type usb trigger on an s110.
That's really odd. I've been mapping with 3.3 since it was released and after fixing the offsets in the geotag window. But even when the Mission Planner geo tagging wasn't working, Pix would work. I'm back to MP to geotag as it's more accurate (not really that big of a deal) though.
130
131
132
133
134
of 449 Next
