Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
          • who me?? lol
            Yea my bad I meant super simple. compass only...if it flies behind you and YOU turn around then the controls will seem reversed but they actually stay the same. I decided very early on NOT to fly in either of those modes because if you learn that way you can really mess yourself up later on trying to break those impulses. One exception is I could see using super simple as sort of a manual type of RTL if you accidentally flew out of sight or something.
          • all is good while it works as designed. orientation of controls in simple mode only depends upon your compass orientation at the time you got vehicle armed. it stays same and it is good.
            super simple relies on the GPS coordinates and alters controls based on that position. when your position flickers suddenly - it will affect controls IF it thinks drone went behind your position on the ground. then it may flip back as GPS improves, then flip again. drone meanwhile will do weird things in the air with no possibility for you to save it.
            that is why based on my own experience I say - do not use 'super simple', ever. not until whole mess with reaction to GPS input will be reworked and improved to the level where it is 100% safe.
        • Nothing needs fixed it's just a different way to fly mostly for beginners. In simple mode for instance when you first arm you copter forward will be away from you pull the stick back and it comes back no matter which way it's turned... if I'm remembering right. But... I crashed myself once for this reason.... if you fly over your head and behind you the stick can 'seem' to reverse but it's not. Pushing and pulling your stick will still make the copter go east or west  etc it doesn't know where you are. So if your flying around and accidentally hit simple mode and it happens to be oriented the 'backwards' way then it will suddenly feel like the stick controls reversed. Changing form a standard mode then suddenly switching to a simple mode without realizing it could for sure get confusing. That's why not many people ever fly in those modes.
          http://copter.ardupilot.com/wiki/simpleandsuper-simple-modes/
        • I wrote about this before. It is beyond me who came up with an idea to reverse controls dynamically,
          It only works in the super simple mode, so, do NOT use it, ever. Combined with a chance of a GPS glitch this thing can start randomly swirling your controls directions at random spots and after that it is nearly impossible to make craft safely back.
          When everything is OK it is supposed to sort of switch back and forth, probably, but in a practical reality it is a horribly implemented feature.
          Simple mode uses compass only and is pretty reliable, use that one and never use super simple as it is only appears to be a good idea until your first GPS glitch. I put a switch for simple mode separate from flight mode selection - it sits on the left side SB long switch while flight mode is on right side 2 switches, so this 'simple' mode can be turned off any moment, if needed, but I did not have any issues with it for a very long time, considering your compasses are working correctly.
      • This reply was deleted.
  • Had a bad crash on Friday - copter stopped responding to input and flew into a tree. GPS was struggling to get sats and I decide to skip getting a lock and fly in AltHold. The copter has bad mag interference. Log is attached.
    Two things I don't understand:
    - Why did I lose control in AltHold, I thought it only used the baro? I can't see any gyro issues.
    - In the log you can see a total GPS dropout. This coincides with the loss of control. Did this affect things? It seems a bit long for a glitch, did something else happen?
    Thoughts appreciated!
    68.BIN
      Hi Andy,
      I can't see any sign that you lost control. I can see you had a sudden increase in vibration and regained your GPS. This may have caused an angle error in your attitude estimate based on the difference between the EKF and DCM. You may have interpreted this as a loss of control.
      I can't see anything to suggest to me why you got the sudden increase in vibrations so that suggests some sort of mechanical problem.
      So from what i can see the copter was accepting and following your control inputs with no more than a 15 degree error caused by a sudden increase in vibrations or getting your GPS back.
      I will need Randy and Paul to look at this one.
      Sorry to see your crash!!
      • Hi Leonard,
        Thanks for looking!
        I think you can ignore the vibrations - this is when the copter was flying through branches and then hit the tree. It sounded a bit like a mower for a couple of seconds :)
        All I can say is that it was not responding to input as I expected. I was flying FPV and had to remove my googles to try and see if I could recover, everything got a bit confused after that. I would say my experience of loss of control coincided with the loss of the GPS.
        I have to say though the QAV250 CF frame is strong! I pretty much only had to replace the props and I was flying again.
    • Another weird thing about this is the HDOP goes to zero rather than 99. UBX messages are still coming in so it seems like the GPS is operating.
  • So did some experimentation with batteries on my QAV250 because of that youtube clip. Turns out the wire end of a LiPo has much more interference than the blunt end, even if the wires are close together or twisted together (I know the wires cause interference but it's interesting that its so pronounced). If I mount the battery with the wires near the compass but folded back I get 80% interference, if I turn the battery end over end I get 20% interference, even though the battery itself is in the same position. I have subsequently resoldered all the XT60's on my small lipos so that they have short tails so that I can mount them with the wires pointing out the end of the quad.
    I haven't flown yet, but I'm pretty hopeful!
