Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
      • Use a flight stand-  I would not ever suggest holding a quad in your hand with props on for testing, at almost face level no less... Esc's and FC's can glitch, a throttle control can get bumped. It does not take much of an accident for that quad to jump out of your hand and bite you, and those spinning blades have much more force behind them than you think.  I have two scars on my chest to back that up.
        What happened? An esc glitched and one motor went to 100% throttle instantly. Your reflexes are not physically fast enough to react to something like that. be safe.
        • Yes... your right... not the smartest move I agree.
        • Sounds to me like another YES vote for a one-motor-at-a-time real time vibration motor test app...  :)
      • I always use my flight stand I made out of some old wood and PVC pipes. MUCH safer than holding on to it :)
      Patrick,
      ++1 That would be a fantastic idea! A simple utility that could loaded and run on the APM/Pixhawk, connected to Mission Planner etc. allowing the user an interface where they could enable and run individual motors at a specific user select-able output level from 0-100% repeatably.The sensors of the FC could be used to gather the information and Mission Planner could then display that information, allowing the user to dynamically balance/diagnose each motor/power system in a safe and easy way.
      Vehicle vibrations are such a major cause or contributor to the erratic behavior of flight controllers, that this seems to me to be a no-brainer. I think this should be as fundamental as calibrating the compass or accelerometers.
      We have utilities built in to Mission Planner to accomplish each of those tasks, why not one to check vibration levels during setup or after a crash for each individual motor? The more I think about it the more I think this is something that not only should be done, but must be done!
      Great idea Patrick!
      Nathaniel ~KD2DEY
      • So, How do we make this happen?
      • Glad to hear an enthusiastic response!  :)  I would run an app like this before and after most every flight.  I hope this thread catches on...
      • +100 ON THAT ^^^
        this would be a huge beneficial feature. as it is, one cannot even test directly in MP if the motors are oriented correctly for the chosen frame / model.  the motors tab (IMHO) needs a serious overhaul.  the "ABCD" generic layout should be re-labeled 1,2,3,4(5,6,7,8..etc) in exact layout relation to the configured model and FC pwm output channels.  this way one could not only confirm correct motor hookup, but also know which motor is expected to spin up during a test.  fwiw :D
  • Hallo
    I am new her. My question, is it realy so that i should not begin with 3.3
      .. and I've updated the comments at the top of this discussion to remove that requirement.
