Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
    • I had that problem too but I change so many thing's, one of them, the compass, I had compass interference near limit but now I change for an ext -gps one, less interference and that effect dissapears, I disable int compass too and enable auto offset detect,  but I'm on first flyings of these modifications yet, perhaps this helps.
      Did you check compass with the flags during flying?, looks very usefull.
  • I might have found a bug.. I updated to the latest 3.3 release today, as well as updated mission planner.
    Now my RSSI display in mission planner occasionally locks up.  Well, pretty often.  I flew a few times, and it happened each time.  I close mission planner and re-start it, and it works again.
    Another issue that might be 3.3 related.  I connected my storm32 gimbal to pixhawk via mavlink.  Now my MinimOSD thinks I'm constantly changing flight modes and gong in to RTL.  It's not changing flight modes, and mission planner displays the correct one.  But the OSD is not happy.
    If either of these is known and has a fix, let me know.
    Thanks.
      ScottW,
      So this is really the OSD that's not handling multiple vehicles or components properly.  The OSD is seeing heartbeats from the vehicle and the gimbal and although they have different a different sysid/component-id pair the OSD is getting them confused.
      Which OSD are you using?
      • MinimOSD Extra.  Micro hardware version from RTFQuads.
        I'm not sure if anyone is developing it anymore..
        But fixing this issue, and adding all the mavlink/mission planner error messages (pre-flight check errors, etc) would be amazing.  If the errors were available, I could fly w/ only goggles, and not need a computer.
    • This reply was deleted.
      • It seems everything was locked on Tower, but I didn't fiddle with anything as it was the first time and figured it was a fluke.
        Weather permitting tomorrow I'll get the laptop out and see what it does, but you say it happens with USB connected also? I hadn't noticed.
        Thanks for bringing this issue up as I was about to blame the PM for the Piixhack not reporting the voltage and amps.
    • I had a similar event with Tower.  It worked fine on takeoff, but after a while I noticed the battery level hadn't gone down and the nice lady kept repeating the same level and other data.
      It did not lose connection, which brings up another thing. When landed and yanking power, Tower did not notify of lost connection.
        • You can switch out of RTL by changing your flight mode even if it failsafed. Not sure what happens if your outside the fence when you do this though.
      • You have Fence failsafe, check your fence config, perhaps
        3702723524?profile=original
            Cala, nice investigation.
            As some others mention, when in RTL, the pilot's input is ignored except for the final landing phase when (if LAND_REPOSITION=1) the pilot can adjust the horizontal position.
            If you hit the fence you should be able to re-take control by changing the flight mode switch and the fence logic won't kick in again for at least 10seconds and 20m (i.e. the fence is temporarily expanded by 20m).  This should give the pilot time to recover without the fence logic jumping in again and again and yanking away control.
            • Randy, if I am not mistaken, I think I was able to control yaw during RTL.... Or am wrong, the last time I used RTL as a "passwnger" was a long rime ago...
