Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
You actually might be right - a bunch of these settings appear to have been changed. I didn't do it so I guess it happened when the firmware got updated. Grrr.
Yeah, I've done all that and its been working fine until the last couple of days
@Nathaniel Tyson Taking off in GPS modes or Alt Hold has been SOP for quite some time with other flight controllers. It doesn't strike me as the best of ideas but nonetheless for many people it's totally normal and if you have a good GPS signal there's really no reason not to.
You don't actually loose responsiveness, it's just a different approach or style to lift off. You raise the throttle up to around 50% and the flight controller ramps up the speed as required to get it to hover height. I think it came from the evil world of DJI.
As I'm a control freak :-) I always takeoff/land in stabilize.
But as I am mostly flying in highlands, before flying missions, as a SOP I always arm and takeoff in one of the GPS modes first, to make sure I have a good GPS lock
I'm the same way I can't STAND the idea of taking off in any other mode except stab. Then I get it to where I want it. Then switch to alt-hold, or loiter, or auto etc. Took me FOREVER to allow it to auto land land and I STILL rarely do so unless I init RTL or end a mission.
if you engage RTL in the end then it is absolutely required to change routine and engage GeoFence so firmware will not let you to start and fly until system acquires acceptable GPS lock and gets your initial position correctly, otherwise your start with GPS coordinates from who knows where may result in RTL into who knows where.
GeoFence is annoying as it takes forever for it to finally acquire that '3d Lock', whatever it is, as it may sit 5 min or so having 13-14 sats in 3D mode before it finally satisfies, but afterward it is flying OK.
Also, after my fights with drone doing toilet bowl and other GPS glitches - an only solution is to buy a separate BEC with a _very_ good LC filter and power your GPS units from that separate BEC, not from your flight controller COM ports. Difference is quite dramatic, in both speed to acquire locks and with in-flight stability.
After all that done I am now always start in position hold and vehicle does not dart sideways anymore, does not try to fly away anymore either. Only other thing - on dual GPS vehicles you still need to change the option to disable automatic GPS receiver swap function until Randy and Co will change logic not to use actual physical coordinates from GPS units but an average delta between positions GPS units return, as different GPS units never return same actual number for coordinates no matter what you do.
Code really needs to be adjusted to take care of that - to trace actual movement delta from both units and not actual coordinates value as latter results in the drone darting from one stable position to an another.
today more flights, more test switching to stab and pos hold and works well
Anyone run autotune with parachutes on board and armed? Just going to autotune a new rig that happens to have dual Skycat's on board and wondered if it would be a good idea to take them off. Wouldn't be all that great if they fired lol! The chutes are designed to save the payload... But not the multi rotor so much at about 17'/sec.
Yes, I run autotune with parachutes on board and armed, no problem
69
70
71
72
73
of 449 Next
