Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
The log where the pictures are from is from your first post. Perhaps you can post the crash log again? I can´t download the log from the second post.
I´m quite sure there is no problem with your esc. While the coopter descends all RCOUT channels are close to each other
and the copter doesn´t flip. It follows the desired attitude quite well:
I think there is something wrong with the IMU of your AUAV. In the ATT readings there is no sign of the spinning we can see in the video. Looks like the FC tried to compensate a wrong detected spin from the IMU:
Hi Dave,
Thanks for that, no problems!
Dave,
Your copter looks like it rotates more than 25 times during that crash. The log you show takes 45 seconds from full throttle to the time it gets to the ground and doesn't spin. Your video takes 13 seconds to crash and spins 25 ish times.
THIS IS NOT THE CORRECT LOG!!!
I can see you don't know how to read logs and are here because you need help understanding what happened. The dev that designed the controllers in arducopter is telling you that the log you provided is not the same log in your video.
Please take the time to listen to the people that are trying to help you. You are currently wasting the time of the helpful people on this forum that are trying to help you.
Yea I’d say your quad looks damn good for a 60M crash! This is probably unrelated but one thing I had happen once was somehow two of my arms got twisted and as luck had it it was two opposing arms hence the motors spin the same direction. What happened then was it could not compensate for the yaw effect that caused so even with full right yaw stick it continued to yaw left. However it didn’t cause a crash and of course it was evident the moment I took off. In my case the aluminum arms get bent slightly in travel. I was amazed at how little it took to create that much of an issue. Just looking at yours I wonder if two of the motor mounts twisted on those round arms? But of course the log would show it trying to compensate with full yaw opposite it's actual yawing.
I had two crashes when a prop tip broke off it looked sort of like that. That was the last time I used cheap props.
Usually with one motor out of sync the copter will drop on that side and the FC will try to correct attitude by increasing RC_Out of that motor. There is nothing like that in your log.
Hi Dave,
sync issues will be clearly seen in your RCOUT log if you had the correct log. You will see one of your outputs pegged to maximum while the others struggle to keep control. You will also see the yaw log go nuts as it spins.
Saw this over at RCG
http://www.rcgroups.com/forums/showpost.php?p=33278428&postcoun...
If you're running BLHeli and 14.2 then you need to upgrade to 14.3
"I've just read that 14.3 is out due to 14.2 having motor glitch issues near high throttle. Check it out."
Would it be possible to post a log with the copoter flying OK? I´m very confused about the log you posted because I can´t find the spinning in the mag or imu readings. In the log it looks like a controlled descent.
There is definitely something wrong with the sensors - in the map logging there i a sudden jump in position along with an EKF error.
67
68
69
70
71
of 449 Next
