Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
  • The Storm32 serial protocol did not work for me. Is there a special firmware on the storm required?
    I tested it with 0.80 and 0.82.
    http://diydrones.com/forum/topics/copter-3-3-beta-testing?id=705844...
    Folowed the wiki for setup. But I can´t control it neither with MP nor with manual RC control.
    I did not get any answer on my request on the bottom of page 160 (link).
    There are also some additional requirements:
    Passthrough of 2 PWM channels to the storm output lines via serial (control of camera).
    Using the Storm link feature as 2. IMU over serial.
    Cheers Gregor
      Gregmaan,
      I've tested the SToRM32 gimbal serial interface with SToRM32 version 0.70 firmware and confirmed that it works.  I haven't tested it with 0.80 or 0.82.  It's possible the protocol has changed or that something was missed during the configuration.
      The additional requests are probably on the to-do list but certainly won't make it into AC3.3.
      • Hi Randy,
        0.70 is a big step behind 0.80 or 0.82e (pan/yaw axis problems).
        I will check if 0.70 is running for me (maybe a configuration issue from my side).
        Hopefully there is a chance to get the 0.80 and above running with AC 3.3
        • Please keep us up to date if you can find any improvement with 0.80 or higher. Thx
      • Randy could you at least take a look at this issue:
        https://github.com/diydrones/ardupilot/issues/2426
        Seems very serious. I'm sure there will be a lot of people using the Storm32 controller with 3.3 since there is native support for it to some extent, but it would be sad to have a lot of people with burned out gimbal motors or broken cameras from that bug :(
        • I also would appreciate a working SToRM32 controller with pixhawk via serial!
  • This reply was deleted.
      Hi Adolfo,
      Drop your RC_Feel to 25 and see if that fixes the problem. If it does put your pids back to the autotuned numbers and see how it feels.
          Hi Adolfo,
          Sorry missed that. Yeh, try the RC Feel and if you want to try autotune again use aggr of 0.05. Your tune looked very nice so I think you can handle a finer tune. We set it to 0.1 so it will handle the higher vibration and flex a lot of frames use. But I personally use 0.05 on most of my frames.
          • Very glad I saw this post. I was getting very frustrated with my Hoverthings modified FPV-Pro. @ 0.1 I was getting very high numbers all around (Stab R - 13~ Stab P 16~), etc... it was a very angry bee in the air and fpv and gopro vid showed it, gave the effect of a video camera in a paint shaker at anything over hover speed. 0.05 dropped the values tremendously (Stab R - 5.35~ Stab P 5.38~), etc... etc... super smooth now even cruising in 20mph gusts. I may have to call in sick tomorrow to enjoy some fpv flying.
