Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
        • T3
          Randy,
          thanks, I'll test it with 3.3 and looking forward to see it implemented in 3.4 officially.
          A little OT: I wanted to submit some PRs but "git config --global core.autocrlf false" is not working for me on windows. Any suggestion?
            You just need to leave the global setting to true. It's much easier, otherwise your editors, unless config correctly will probably screw it up.
            I thought randy backed out of the line feed change?
      • I hope this will make it into 3.3 also :)
    • we all hope so...maybe one day we will have complete stabile version and stop TESTING bcs. this way I have feeling we are doing only that.Dont get me wrong,i respect developers work but it would be nice to stop developing for a while...Thanks for great effort...P.S.third compass would be great :-)
        Emin, as others have said, there are stable versions of flight code for copter and plane that you can use.  The reason this project develops quickly is because there are lots of people writing code and lots of people testing.
        We will never stop developing and never stop testing.
        We have said it a thousand times, if you are not actively testing a new feature then please use the stable versions.
        • I did not meant to say to stop developing!Everybody here keep repeat like a parrot;use stable version than,use stable version...are you seriuous?what is stable version?3.2.1,i don't think so...it has all the problems bcs of witch we moved to 3.3;does SOLO have stable version inside,or we have to stop it with steping on it like Colin did it on presentation?
          I wanted to say;once we get to what you call stable version you should keep "ironing" that until its perfect without adding new functions ..TO THAT VERSION...this way developers stop looking to older version  leaving it with all problems it have...when you have 10K $ multi you do not want to experiment and risk some minor problem which can lead to disaster(yes I do have testing rig,in fact 2 of them,but each settings is different,so results as well)...did you ever ask yourselves why so few professional AP rigs using Pixhawk even tho it is most advanced controller out there? No mater how hard I try to convince people to use Pix with all its advantages,answer is always the same;oh no,we never know what might go wrong with that,is it stable now etc. and than they swear to DJI FC or some other(who often use solutions from Arducopter).Ok maybe you are concentrated on selling great numbers of small multis (why power module is for 4S only,why we don't have it for 6S,8S..12S..why don't you develop that if you are for developing,or GPS wich is 3 yrs old,or OSD,lidar etc,etc) why the hell you do not offer stable compact version of your hardware as well as a complete integrated solution??
          Please do understand that if somebody criticize something,he is not an enemy of this great project..i would never fly anything else but Arducopter and I am here since APM 2.0..i just want when I recommend Pixhawk to somebody,and build him few thousand $ multi he don't call me every day and mumbling about problems whit this and that...
          Please keep on with a good work and thank you all developers out there!
          • +1
          • I find this as a very constructive criticism. Emin is right in many points.
            And I sadly see the same thing he does: Many people out there fly DJI stuff and swear on it. Just because it is more expensive, they classify DJI equipment as professional.
            Arducopter can do things DJI stuff won't even get close to but somehow their smart marketing strategy blinds people out there and they sell their stuff at the price tag they want.
            Recently a friend of mine wanted to get into AP and laid his eyes on the new DJI Inspire 1. I recommended the 3DR Iris+ (at the time SOLO wasn't out yet). No matter what I did, I couldn't convince him. There are a lot of people out there (mostly people that don't know much about these stuff); they believe in marketing hypes and go dump bunch of money on systems that aren't half as good and capable as Arducopter but look physically more charming.
            So in my understanding when Emin said "Stop developing", he really meant "Stop adding new features till the current version becomes completely stable."
            And I do understand one thing as well and that is sometimes fixing a current problem automatically introduces a new feature and this somehow keeps going. This is a dilemma and I understand the difficulty. But this is a problem for people flying thousands of dollars worth of equipment.
            I hope developers and other members won't take me wrong. I just wanted to add my point to Emin's.
            I really think that Arducopter project is the best thing out there and I am closely following it and waiting for the day it will be a great tool for everybody and bury other commercially super expensive systems into the ground...
            • I have some sympathy for this point of view. I think most people given the choice between features and stability would take stability given that without it you potentially incur thousands of dollars of cost. I have been mulling to offer the maintenance of a release branch (given that's a lot of what I do in my day job), but I'm not certain I have the time.
              People need to understand something about software though - you can have stability or you can have features, but you can't have both. Ok I'm exaggerating a little, but any change has the potential to introduce further issues so generally in software "stable" branches do not add features, only bug fixes. I think doing this for 3.2.1 for instance makes a lot of sense, especially for all the APM users.
              I also wonder whether the model is right. At the moment a line is drawn and everyone moves on to the next release. I think it might be better if the release branch was stabilized for a lot longer, with a greater degree of overlap (in time) with the dev branch. Obviously this takes some effort as someone has to identify fixes that need to be merged between branches, but I think its probably worth it.
              I think also it might need a bit more formalism - i.e. have a bug list for the stable branch, identify commits that should be merged etc.
              My $0.02
Aug 25
