Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
      • Hi Nathaniel
        I do have a switch for RTL, I have several copters set up different ways and under the duress is was in, I forgot which switch position I needed.  The reason it did go to RTL when I turned off the radio is that I am using a EX-UHF receiver, and set it to go to failsafe when I turn off the radio.
        I have all my copters set this way just to have a backup way to go to RTL, or in the case my radio transmitter dies or if I get out of range..
        I set it to failsafe to RTL by setting the RTL switch on and verifying the RTL state in Mission planner and then using the bind button on the receiver.   If the receiver detects no signal, it goes to that setting..
        thanks for the info about setting the RTL height, I will implement that before I fly this again.
        As to the vibration, two things I found  one motor has a lot of vibration, the other three had some also, but not as bad.  I have DYS BE5208 330KV motors and they are large pancake style motors.
        I am trying to figure out a way to balance them, I wish there was a dynamic balancer on the market!
        The other thing I found is there is a canopy on top to the platform that the PIxhawk is mounted. The lower part of the canopy is touching the arms where they connect to the frame.  The vibrations from the arms are being transmitted to the PIxhawk, not from the base which is mounted with anti-vibration foam tape, but from the top of the canopy touching the top of the pixhawk.
        I reworked the area so that the canopy is isolated from both the arms and the pixhawk.
        also, I re-worked the mount for the pixhawk by making a double isolation mount. a mounting plate is mounted with anti vibration material (3/16 Sorbothane) and then the Pixhawk is mounted to that plate with the same material (Sorbothane)
        I think I might be ready to try again to do some testing, after I do a compasmot to see what that looks like.
        Thanks much..
        Any suggestions about balancing pancake motors?
        Richard
        Kd5zzl
          Hi Richard,
          If I understand you correctly, the canopy issue is a great way to get massive vibrations. Anything that can vibrate against something with a small gap will cause much greater problems than rigid body transmission of vibrations. So you should see an improvement after fixing it.
          Motor vibrations are often caused by the shaft of the motor not being set deep enough in the bell. This can let the bell move up and down slightly (sometimes more than slightly). If this is your problem you can loosen the grub screw holding the bell and move it down so it is snug against the bearing. Be carefull as there is a fine line between just snug and damaging the bearing.
          • Thanks Leonardthall, for that insight.. I checked the shafts for play and I don't feel any, I can't see any wobble either, but it is possible there is runout in the shaft i guess, this forum is a great place to get help
            Thanks Guys
            Richard   KD5ZZL
          Richard,
          With respect to balancing the pancake motors. I suspect the process will be similar to balancing other types of motors while perhaps being a bit more difficult due to their limited cross section. However if you have an iPhone/iPod you can try this method. There are similar Android apps available, however I haven't found one quite as good.
          https://www.youtube.com/watch?v=RItntpZZH4g
          The process is quite simple really, and very effective.
          73
          Nathaniel ~KD2DEY
          • Hi Nathaniel
            I was going through the radio setup, after isolating the AP and making all the suggested changes other than doing the motor balance (I may just replace them for dynamically balanced motors).
            and found something very interesting..
            In my flight mode setup, I found that "super simple" was ticked for the position hold flight mode..
            Could make for an interesting FPV flight... Don't try it!
            I have an idea how it might have gotten checked, but its a long story..
            The question I have is it that "can super simple be applied to Position hold'
            IT did seem to go one way, when I command another.
            Richard Kd5zzl
              Richard,
              Yes, simple mode and super simple mode can be used with every flight mode except ACRO and Drift.  In those modes, it's simply ignored.. it won't do anything bad.. it simply won' do anything.
              I've checked the wiki and it says what Nathaniel says so i'll update the wiki now.
              Thanks for the report!
              Richard,
              I'm afraid I don't know the answer to that one. According to the wiki it only applies to Stabilize, Sport, Drift and Land modes. However I don't know when the pages were last updated. It sounds like you may have had some experience with it already. If you are feeling adventurous try it the next time you fly (non FPV of course).
              I'd love to see another log after you finish your vibration reduction regimen.
              Nathaniel ~KD2DEY
          • Thanks Nathaniel,
            I will watch the video
            BTW, The compassmot ran and it looks like my vibs are acceptable, which surprises me, when I hod the arm while running it up, It feels pretty extreme.  Maybe the AP is happy now, but I still want to get my motors running smooth so all the screws don't fall out while flying!
            Thanks, I've attached the Compassmot result
              Richard,
              I'm sorry if I'm not reading the meaning in your comments correctly, but I just want to be sure you understand. The CompasMot is used to determine the amount of electromagnetic interference caused when you apply increasing amounts of throttle. it doesn't have anything to do with measuring vibration levels.
              If you can feel "Extreme" vibration then you definitely have a problem. You mentioned having one motor with bad vibration. If you can't eliminate the source of the vibration, replace the motor. I would break the vibration reduction into four steps. First ensure that your frame is as rigid as possible and that your flight controller is isolated from any part of the frame, also ensure that all cables connected to the FC are secure but not taut. Second step is to ensure that the props are all properly balanced. Third balance your motors following the method provided in the youtube video linked above. Finally install the props and dynamically balance the prop/motor combination one at a time while the frame is weighted down at 50% throttle using the same method you used to balance the motors themselves. It's a lot of work, but it pays big dividends. A smooth running vehicle flies better.
              You might ask why not skip the motor balance and just balance the prop/motor together, don't, it's better isolating each source of vibration and reducing the vibration at each step. Then in the last step adding the smallest correction possible.
              Once you have completed the vibration reduction steps, follow the instructions here to measure your vibration levels.
              Best Regards,
              Nathaniel ~KD2DEY
    • Richard: another consideration, Why don't you use a switch to trigger RTL? It's looks more safe than turn off the radio
