Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
          Hi Aleksey,
          There is a difference between Alt_Hold and Autotune flight modes in the way it behaves.
          Randy is fixing this now and we hope this should fix your problem.
          Thanks for your input!!!
          Hi Aleksey,
          We will check to make sure that the copter will disarm in autotune if autotune has not finished.
          I am the person responsible for autotune and have done an amazing amount of autotunes testing it. Autotune defiantly disarms once it has finished. However, I am not sure if it disarms when it has not finished.
          If you find the results of autotune have not worked well for you, can you please provide a log of the autotune and a log of the test flight.
          Thanks for your feedback and input!!
          • 1. OSD: I use Cuav MinimOSD with r800 FW and Mavlink setting.
            RSSI Problem. In MP in tab Status I see RXRSSI is 90. Ok, RSSI in Pix is transfer.
            Good. And in OSD RSSI is 0. Why?
            Settings in Pix on RSSI: RSSI_PIN=103, RSSI_RANGE=3.3.
            In 3.2.1 FW no problem with RSSI on my octa.
            May be SR2_* params need correcting?
            2. OSD: Sometimes (i don't understand relation) Armed icon -> # on right from
            STAB# or ALTH# dublicate in place first letter current flight mode,
            in result I see: #TAB# or #LTH#.
            3. Transfer logs in MP 1.3.28 from USB - problem on big logs. For example, 15mb log, i
            connect PIX to USB. In begin bytes transfer i see in MP - 200-300kb in sec first 2-3min.
            Ok, download 7mb for ~3 mins. I select task log download from 10 minute and I see
            speed - 500-1000 BYTES IN SEC!!! On modems (433, 915mhz) situation same.
            Why speed very low after a while to download large log?
            4. MP is loaded and disconnect from port 30 (USB PIX). Select port 30. Good. I connecting
            Pix to USB, wait for load brain and press Connect in MP and i see connect error. Ok.
            I press on comport dropdownbox, select port 30 -> click -> Connect -> connect is good!
            This is BUG I've been watching. Trifle, but unpleasant.
            5. AutoAnalysis on all my logs in archive say: first alert "System exit" <ok>, second alert
            "Bad input file" <ok>. "Review a log" work with this *.bin's.
            My tuning yesterday log http://rghost.ru/89SYbbbnJ  8.5mb. Password "zxc". This forum max 7mb accept attach.
            PS. I have 7 logs from tuning session. Need? I can sent to you.
          • Hi Leonard!
            Until shake logs, mini my comment:
            There is a third hour of downloading the 15-meter log ... How? .. :) No, not via a modem through USB. Why is the third hour?! Probably some kind of bug. :) IMHO. Later I will write more in detail as the logs spool.
            PS. In console i see this now:
            INFO MissionPlanner.MAVLinkInterface - req missing 13263120 180
            bps 1831 loss 4357 left 136 mem 57.3515625
            INFO MissionPlanner.MAVLinkInterface - req missing 13263210 90
            bps 2007 loss 4357 left 0 mem 57.2578125
            INFO MissionPlanner.MAVLinkInterface - req missing 13263390 180
            INFO MissionPlanner.MAVLinkInterface - req missing 13264110 270
            INFO MissionPlanner.MAVLinkInterface - req missing 13264470 90
            bps 2384 loss 4357 left 0 mem 57.279296875
            INFO MissionPlanner.MAVLinkInterface - req missing 13264650 1530
            INFO MissionPlanner.MAVLinkInterface - req missing 13264740 270
            bps 3222 loss 4357 left 238 mem 57.4443359375
            bps 3222 loss 4357 left 133 mem 57.4443359375
            INFO MissionPlanner.MAVLinkInterface - 1 lost pkts new seqno 230 pkts lost 2
            INFO MissionPlanner.MAVLinkInterface - 1 lost pkts new seqno 231 pkts lost 2
            INFO MissionPlanner.MAVLinkInterface - req missing 13264830 90
            INFO MissionPlanner.MAVLinkInterface - req missing 13265280 90
            bps 2146 loss 4359 left 0 mem 57.291015625
            INFO MissionPlanner.MAVLinkInterface - req missing 13266270 360
            bps 2423 loss 4359 left 0 mem 57.3173828125
            INFO MissionPlanner.MAVLinkInterface - req missing 13266360 270
            INFO MissionPlanner.MAVLinkInterface - req missing 13266900 360
            bps 2183 loss 4359 left 32 mem 57.287109375
            INFO MissionPlanner.MAVLinkInterface - req missing 13266990 180
            pps. load cpu my comp 30%.
            • Vitashchi SD card i kachay s neyo....
              • Russian translit:
                V resultate tak i sdelal cherez 4 chasa kogda vernulsya k compu. :) Ochen' ne hotel razbirat' copter iz-za loga. No pincet i dlinnogubcy s tonkoy otvertroy i fonarem v zubah pozvolili sdelat' etu operaciy. =))
                English:
                As a result, after 4 hours both returned to the computer and saw the sad process - all turned and pulled out the SD card. It did not want to disassemble the copter so rocked via USB. But most "medical" tool to help remove the card, without unscrewing the cap. :)
                • Sorry bro, forgot another helpful thing - using a different USB cable and/or twisting the pixhawk usb/led adapter wires separately from each other i.e. usb data+vcc+gnd together and i2c data+vcc+gnd  in a different batch.
                  • I LED special no connecting in system. I2C only compass.
                    If cable bad - on first secs speed would be low. Cable is good.
  • Hello,
    I've tried Autotune with my hexacopter running 3.3.RC3 and it all went well. Now I tried RC5 and suddenly autotune did not finish all axes, just roll and pitch and did not save the values anyway after switched off. Futhermore I'm getting warning "Error compass variance" any time I run more then 10% of throttle. I've recalibrated compass on Pixhawk and I know I have high offsets for internal compass. But I use Zubax GPS with own compass and this one is working fine, low offsets only. So I wonder why I get this warning..
    Thanks.
      Hi Michal,
      How long it takes to complete autotune may vary depending on a number of factors. You can do 1 or 2 axis at a time by setting the autotune bitmask, AUTOTUNE_AXES.
      Sorry I can't help you with the variance issue.
