Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
      Wes,
      I think the vehicle has a very bad motor imbalance.  Maybe some ESCs need calibrating or there's a weak motor or it's leaning or something to that effect.  The vehicle is spinning counter-clockwise (CCW), to counteract this the CCW motors (1&2) are increasing to maximum, the CW motors are going to minimum. The motors have hit their limits and can't provide any more rotational force but still the vehicle continues to rotate.  Motor problem!
      3702587125?profile=original
      • Thank You!
        So it is likely that one of my ccw motors is failing, (motor 1 or 2).
        I might try tying this quad down and running the motors up 70% or so and see if one motor is getting hotter than the others. The hot motor might be the bad one, unless it is an esc issue...
        What is still a mystery unrelated to a possible motor issue is the video I posted, with the aircraft on the ground after landing from this bad yaw problem, Mission Planner's artificial horizon is going crazy rolling around all over the place displaying compass variant error, GPS error and so on.
        • I tested the motors with motor test and watched the amps on the OSD, all motors are with in about 1/2 an amp of each other.
          I did an esc calibration just to be sure, and the results were still with in about 1/2 amp. Highest 11.9 and lowest 11.4.
          I ran the motors at 70% for about 10mins with no notable difference in motor temps.
          To me this rules out motors or esc's as the cause of the problem.
          • Wes,
            That graph looks all too familiar.
            I don't know what your frame looks like, but I strongly suspect that the motors are not level.  One or more motors which are tilted by as little as 2 or 3 degrees can cause a persistant tendency to yaw in a partitular direction.  The controller will have to compensate by slowing down two motors and speading up the other two.  Check each motor with a level or a square against a common surface.  It can be difficult to see, but if the controller is not in the way you may be able to sight along the arm and see that a motor is not exactly parallel to the motor on the oposite side.  If your frame has round tubes, rotate the motors into alignment.  If not, place a paper or light cardboard washer or a few layers of masking tape on the low side of the motor between it and the mount to level it out.
            • The motors pulling same amps when run individually doesn't mean they're not fighting each other in flight due to the motor levels being off.
            • I will check the motors to be sure they are level.
              I swapped FC's tonight and flew again, all is good, smooth steady heading hold until I made a few yaw movements and there it is again- unstoppable yaw.
              The aircraft has power to spare, all motors are pulling nearly the same amps at full throttle, it can't be the FC as that has also been swapped.
              I must be missing some thing,
              In the morning I will check for level motors.
                Wes,
                I totally agree with Brad, GlennM that it's a most likely a motor leaning.  Not to get too picky but I'd prefer if we could take the problem off to another discussion at this point *except* if you find it doesn't happen if the vehicle's put back on AC3.2.1.  That would indicate that we're more sensitive to motor imbalances than the previous version and I'd be happy to review of log of AC3.2.1 running on this vehicle.
    • Wes,
           It is my understanding that the yaw controller has changed in RC 3.3. Your Yaw Rate P is currently set to .2 from you r9.bin file. My new Rate P settings in 3.3 are often as high as .8 from ~.2 in RC3.2. I would recommend you re run your autotune on the yaw axis and probably all other axis as well to see if that helps.
      Also you are having clipping due to vibrations on your acel just prior to the rotations starting so there is likely a vibration problem to be solved as well.
      On a side note it looks like you've managed to spin 8 times if the logs are correct. I bet that was a fun thrill ride. Hope you can figure it out.
      • Thank you for your reply.
        Would you auto tune a multi that is yawing out of control?
        When I loaded 3.3 this time I loaded rover first to clear all settings so the 3.3 install would be clean. Default setting.
        This weekend I spent several hours balancing props to a gnat's hair starting with a new set. I remounted the FC using small squares of Kyosho dampening gel- the green 3/16 thick type.
        Vibration levels dropped from +-3 to +-1. If I still have a vibration issue it would have to be a failing component, motor/ esc/ FC.
        I have an extra Hawk FC so I am going to try that first.
    • I just tried one test flight after moving to 3.3-rc8.  I was under oak trees in the backyard so I didn't do much but it seemed very stable.  I have a M8N and it seemed to toilet bowl some in Pos Hold.  It took several attempts to get a good compass calibration that pointed where the quad does.
      Auto analysis reports many things not logged in spite of Log_Bitmask being set at 43006.
      What should the bitmask be set to?  And are there other parameter changes that might help the M8N?
      Log attached.
      2015-08-12 19-57-23.bin
      https://storage.ning.com/topology/rest/1.0/file/get/3702586814?profile=original
