Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
        • T3
          Neil,
          it is most probably due to an inconsistency between the accelerometers induced by vibrations from the buzzer when switching flight modes. Some discussion can be found at: https://groups.google.com/d/msg/drones-discuss/1xgJUpENNO4/gyk76r5E...
          What is interesting is that the vibration damping is separate in your case. Can you post a picture of the setup?
  • Do anyone know if I can use solid state relays on my PX4IO board and how should I setup em (map to specific RC channel) if answer is positive.
    Is it possible to turn em on say on "arm" action?
      Not sure this is really an AC3.3 testing question so perhaps shouldn't be raised in this discussion.  In any case, the Relay wiki page is here including instructions on how to control it from a switch.  It's not possible to link it to an arming action.
      • Thanks Randy,
        I've seen this page, but I'll take closer look at it once more.
    Hi Guys ,
    this is the video of our first optical flow test with VR Brain 5.2 lidar and APM 3.3rc8 ... there are some bugs in pre arm check so we disable for start the test .. so actually is a good option only for dev and beta tester .
    https://www.youtube.com/watch?t=112&v=HbAxfs5TUC0
    best
    Roberto
      yeah, the optical flow on that copter is looking great actually!
        Yes Randy but is not already available for end user ... the pre flight check need patch and some times in initialization stage there are some iusse and then then the drone drift and don't mantain the position so well as when it work fine so we are near to have a good option , but need a bit of work to do for finish the implementation could be great if in 3.3 official will be finish or is too near the next release ?
        best
        Roberto
        • After weeks of unsuccessful attempts using this $52 version of PX4FLOW optical flow sensor (http://www.goodluckbuy.com/px4flow-v1-3-1-optical-flow-smart-camera...), finally I was able to run it with RC8. The problem is there is no indication for the scaling factor of FLOW_FXSCALER and FLOW_FYSCALER in the wiki page. The latest MP has a description range of -200 ~ +200 and I was able to guess 200 means 20%. So the suggested range is -20% ~ +20. This version of PX4FLOW requires a scaling factor of 350%
          EKF_FLOW_GATE,5
          EKF_FLOW_NOISE,0.15
          EKF_GPS_TYPE,3
          FLOW_ENABLE,1
          FLOW_FXSCALER, 3500
          FLOW_FYSCALER, 3500
          LOG_BITMASK,131071
          The performance is quite good. Under windy condition the drift is below 0.5m with altitude of 1.5m. I found two cases that optical flow can’t seem to hold position:
          -        Limitation on height: As soon as I raise the altitude around 6m the quadcopter started to drift away. This problem is reproducible every time. The sonar I used is MB1242 I2CXL-MaxSonar-EZ4.
          -        Fly mode switching: It worked pretty well from Stabilized ->Altitude hold (a few seconds)-> LOITER. However after flying with altitude hold mode for a while (30 seconds+) then switching to LOITER the quadcopter will drift to one direction. The only way to get it to work again is to land and Disarm->ARM. (GYRO drift?)
          I have two questions:
          1. Is there a height limitation with PX4FLOW optical flow sensor? I was hoping the optical flow sensor can solve the flyaway issue under GPS glitch condition.
          2. Can PX4FOW work without sonar? The current altitude hold works pretty well without sonar and sonar range is very limited.
          Thanks to the development team for doing such an excellent job.
          *Note: I don’t recommend using this version of PX4FLOW sensor with GPS. I could never get a GPS lock when the optical flow sensor is powered. The EMI interference is unacceptable.
          • I guess there is limitation on PX4FLOW focus. Did you set up sensor focus as it is said in Wiki? I got mine adjusted to 3m distance, and it was NOT set up correctly out of the box (as it is also said in wiki).
            I am currently using:
            PX4 + IO(stack) + 3DR FLOW (i2c) + MKBL ESC(PWM)
            IRIS X quad.
            The thing is that on 3.2.1 firmware my PX4 failed to see PPM receiver. I moved on to 3.3 rc8, surprisingly it worked very well (I haven't autotuned copter yet, because build is in progress).
            Flashed FLOW module with recommended on wiki 2014 firmware and adjusted focus.
            Funny thing: I was trying to tune flow_Scale indoors and I had not enough limits as in case above, but when I got outside in good lighting conditions limits ended up 0%.
            Concerning sonar, there are recommendations to use Lidar height meter because of dire unreliabilities of sonar. I haven't tested posHold and sonar alt hold yet, but these actions are very close on my work list, so we can compare results.
            • Hi, Marco:
              Interestingly enough after reading your observation regarding the Flow_Scale I tried it outside and guess what I am using 3150 instead of 3500. However I can’t be sure if this has anything to do with doing a 6M refocusing. I did follow the instruction and did a 3M focus adjustment on the PX4FLOW sensor before using it.
              It appears that there is no change of the optical flow LOITER drifting issue reported before after refocusing at 6M. This time I found even at 4M ~ 5M range it still happened just slower. So I have to assume that the optical flow operation range is below 4M. This is quite sad that the flyaway issue cannot be prevented using this optical flow sensor or can it?
              The new beta Mission Planner did issue a warning when you entered the FLOW_FXSCALER and FLOW_FYSCALER beyond the -200 ~ +200 range. However it did accept the value which is good for the sensor I am using now. I wish the next release RC9 can solve the mode switching issue so user can enter the optical flow LOITER from other modes.
Gremsy liked Gremsy's profile
Mar 12
DIY Robocars via Twitter
Nov 27, 2022
Nov 24, 2022
Nov 24, 2022
Nov 24, 2022
Nov 24, 2022
Nov 20, 2022
Nov 20, 2022
Nov 8, 2022
Nov 8, 2022
Oct 23, 2022
Oct 23, 2022
Oct 23, 2022
Oct 19, 2022
Oct 18, 2022
Oct 13, 2022
