Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
      Marcus,
      Thanks for the testing, report and logs.
      The usb-connected is only visible in the 9th bit of the DU32 message in the dataflash.  From checking the logs it looks to me like that bit is unset (meaning usb is not connected) so it seems to be working.  Also the battery failsafe triggering in these logs shows that it's ok.
      The issue with the vehicle switching to LAND instead of RTL is because the vehicle was within WPNAV_RADIUS of home.  That parameter was set to a very large 30m (i.e 3000).  It's not intuitive that these two are linked so I think I'll hard-code the RTL vs LAND distance check to perhaps 2m or 3m.
      • Randy,
        thanks for information an clarification.
        So i looked at the wrong bit, sorry...
        That the WPNAV_RADIUS is linked to this is new for me.
        The failsafe-wiki says:
        "Return-to-Launch (RTL) if the FS_BATT_ENABLE param is set to “2” (“RTL”) OR the vehicle is in AUTO mode, has a GPS lock and are at least 2 meters from your home position"
        I think, hard-coded is a good solution.
          Marcus,
          Yes, the wiki is misleading.  Here's the fix to hard-code it to 2m.  So we can push that into -rc10.  I was hoping there wouldn't be an -rc10 but it's very likely there will be but it should be soon and have very few changes.
            Only 2 meters Randy? Is not too little?
            "WPNAV_RADIUS" in my opinion was an acceptable value, and configurable, without recompiling the code.
            With my big birds for safety reason i takeoff and land about 6 meters from me, and it would help him to do the LAND instead RTL in that radius.
            My $0.02...
            • Maybe we should create a new parameter...
              Or we leave it as it was and update only the wiki.
          • Randy,
            thanks for the fast response.
  • Weird behavior with RC9 and latest Tower app
    Copter Failsafed for battery and its action is LAND. As it landed switched to Loiter even if there was no GPS coverage.
    Strange and possibly dangerous. Already opened issue for Tower, but RC9 engaging Loiter even without GPS coverage is not good also.
    Screenshot of relevant portion of the log attached
    3702075642?profile=original
    https://storage.ning.com/topology/rest/1.0/file/get/3702075642?profile=original
      Luis,
      regarding the compass variance error, it may be a real problem with the vehicle.  In particular I see the EKF variances climb a lot once the throttle is raised.  Also the field length of the magnetic vector changes a lot when the motor is running.
      In the graph below you can see the current (blue) and how the mag field length drops from 535 down to about 300 as the current goes up.  Also look at the right side of the graph where whenever there are current spikes the mag field length drops a lot.
      I see you're using compass-mot.  You may want to re-do that setup or try turning it off after moving the compass further from any sources of interference.
      3702589113?profile=original
    • Apparently is a Tower behavior....
      https://github.com/DroidPlanner/Tower/issues/1108
      although the Loiter change would not be possible.
      btw: Thanks Randy :)
      Flight mode changes to Loiter on disarm · Issue #1108 · DroidPlanner/Tower
      How to replicate - -Arm in Stabilize (droidplanner tells me its armed) -Disarm (still in stabilize) Copter disarms then flight mode on DroidPlanner c…
        Luis,
        As discussed on mumble, this is definitely a bug that we will need to fix asap.  It seems we allow arming in Loiter with no GPS if the ARMING_CHECKS are set to zero.  Even though the arming checks are zero we still shouldn't allow this so we will fix that up.  Looking back through the code history, it seems even in AC3.2.1 it was possible to arm in Loiter with no GPS (if ARMING_CHECK = 0) but the GPS failsafe would trigger immediately and the vehicle would disarm.
