Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
As I've written on other thread before, after 3.3 is released the entire code must be grepped for the strings, as it has been done before for 3.2.1
Hi Paul,
please, can you share a litle more your hardware and software to use Taranis (LUA) for telemetry ?
thanks a lot
Sure, it is in my opinion a #1 thing to do for any Taranis owner.
This thread
http://diydrones.com/forum/topics/amp-to-frsky-x8r-sport-converter?...
and this video
https://www.youtube.com/watch?v=xWRNhiJ1BNk
has all the info.
Essentially you will feed standard telemetry into a Teensy board that is connected back to X8R that will send it all back into Taranis. On Taranis you run a specific LUA script that gives you all required data and 'speaks' all important messages to you. That was a core of my question as I need to sync up those messages now somehow and not sure if anybody looked at that yet.
Paul,
thanks a lot.
The messages at the Ground Stations (like Mission Planner and APM Planner) are not pre-recorded wav files but generated by the TTS engines from the computer operating systems.
The best way to list all the messages from the source code is to do like I did awhile ago for 3.2.1 is to grep PSTR(" and list all the messages including punctuation and capitalization inside the quotes.
Well, it is a problem a bit as on Taranis it looks for a code of the message and then plays a file with same filename as a code of the message. OK, I will try to figure it out.
The code on the Teensy has to be redone to cope with the new messages
Would you be so kind as to post your serial port settings that work for you with 3.3? Thx
Thanks a lot Randy and all devs involved!
+1
