Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
          • Well I have a 3 axis brushless. Elev and azim are on pass throughs from pixhawk. Elev can be controlled by pixhawk too.
    • Only if you have a brushless gimbal controller between the brushless motors and the APM.
  • hi, is it possible to connect a brushless gimbal (not servo!) to my APM?
    thanks for any help.
  • I reflashed all my ESC's (RCTimer 16A) to BLHeli 14.1 with damped-light, medium high from SimonK and now I get a serious wobble/vibration in flight. Is this just a case of needing to run autotune again or should I be looking for something else? This is a QAV250 setup. If it needs retuning what should I change manually to get it to a more stable place where I can confidently run autotune?
      Hi Andy,
      The motor breaking probably means you need lower Rate gains. I would say drop your rate gains until you don't get oscillation then do autotune again.
      • Hi Leonard,
        Can you tell me which setting this is?
        Thanks!
          Hi Andy,
          Drop Rate P, I and D for roll pitch and yaw by 25% at a time until you stop oscillating. And make sure Stab P is about 5.
          I am assuming your wobbling is fast and not slow....
          • Hi Leonard,
            Thanks that was it - amazingly I had to drop them about 75% to get a stable hover again.
            It was a fast rotating wobble, a bit like a spinning top just before it falls over.
            Is this because the motors are more responsive now or something else?
            I've read to the end of the RCTimer 20A thread and it seems a lot of folk are unhappy, but these have flown fine on SimonK for a while now.
              Hi Andy,
              I think this is because of the active breaking. This speeds up the response one the downward slope and increases the gain.
              That is my theory but I have not done any testing to confirm my conclusions.
              • Hi Leonard,
                So I tuned again today and the copter is almost unflyable. It tries to roll on takeoff and has a very delayed reaction to input, especially on the roll axis - and when it does roll it virtually rolls over. Beginning to wish I'd stayed on Simon K now! I've attached the tune logs from roll and pitch plus a log of flying it afterwards. There is a still a very slight high frequency oscillation I can hear when its tuning. Let me know if there is anything I should do differently. Thx.
                81.BIN
                84.BIN
                82.BIN
