Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
    • No problems here.   Stabilize, alt hold, pos hold, auto mission, land all worked fine no issues.
      • +1, No more change mode issue
    • This reply was deleted.
      • Re-calibrate your ESCS and make sure your throttle hover is set back to 50% until you get it worked out.
    • +1 from me - I have done many flights on my QAV250 with rc2 good success. My only snafu was my serial settings getting borked, but I suspect that's a MP issue.
      BTW did you see my question about "Accelerometers not healthy"? I was flying one day with rc2 when it was much colder (0C rather than 15C) and I was getting these all the time. Does switching off IMU2 disable it for pre-arm checks also?
        • you should ALWAYS ALWAYS ALWAYS let it acclimate before taking off. You are begging for disaster otherwise. The sensors NEED to acclimate. If it is warm inside and cold outside I always let it sit unplugged for a good 20 minutes before even thinking about plugging in the battery. These MEMS units are super sensitive and heat/cold can affect them in all kinds of scary ways.
          • Is it possible to incorporate temperature calibration similar to the one that implemented in OpenPilot Revo? It seems that OpenPilot is essentially dead now, but they had lots of good ideas, which may improve APM, thermal calibration is one of them.
            • If using a hmc5883L it would [and most things are still using this] but if you are using a hmc5983 then I don't think it needed as it already incorporates temp compensation.
    • T3
      Be careful with the built in buzzer. It may interfere with the Accels and the compass.
      I've got one but I've only put it through some bench tests, I've never actually flown it.  It seemed ok to me except it doesn't allow easy connection of the ground wire to the ESCs.  We recommend connecting the signal and ground wires for all ESC to the Pixhawk because without it the ESCs can be confused about the voltage coming across the signal wire which can lead to ESC reliability problems.
      • Altimeter, geo-reference, laser range-finder
        When a laser range-finder is used is it possible to use this altitude as the default for the geo-reference process.
        As I understand, currently laser-altimeter is not used for auto missions, and probably either barometric or GPS is used for geo-referencing.
