Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
      Hi Nate,
      If your props don't spin up when on a slope then you haven't set your THR_MIN parameter high enough or have not calibrated your ESC's. So I would start from there.
      Start with default pids and do a bit of manual tuning to get a copter you can fly in Alt hold that is stable.
      If you are getting oscillations after auto tune it is often because your frame is too flexible or you have got a large flexible gimbal installed. If it is the gimble then try an auto tune without the gimbal installed. Then do an Auto Tune and see how it flies without the gimbal installed. If it flies well then attach the gimbal and fly again. If you have oscillations with the gimbal, back off the roll and pitch rate values by the same amount say 0.75 x and fly again. Repeat that until your copter stops oscillating and you have your tune.
      If you have a flexible copter or a copter or some other issue, sometimes you have to manually tune.
      • (attached below)
      • Calibrated my esc's a few times,with no differences. However when adjusting the D rate, there are changes, the 'props not spinning on a slight slope' issue lessens or worsens.
        I do have a gimbal attached, semi-popular GLB storm 32 3 axis gimbal
        http://www.goodluckbuy.com/3-axis-brushless-gimbal-camera-mount-wit...
        Frame is really rigid, doubt, flex is an issue here.
        It flies ok in alt hold, but as i said is either like a feather or super twitchy no matter.
        Will try the tune again with out the gimbal and report back
        Also, thanks to you and everyone else who replied
        oh and here are my logs and param file in one link
        https://www.dropbox.com/sh/i4vqz33pi00yql0/AACS4NIW5FoZ4rrWbPN9z3AC...
    • We've got the same copters with 15" props, but mine's an X8 with sunny sky 4108s 14 480kv motors.  Tuning maybe similar though.  Give this a try.
      https://storage.ning.com/topology/rest/1.0/file/get/3702631623?profile=original
      • still wayyy too twitchy with these settings. :(
        • This is a pain, but it seems to work.  I do three sets autotune's three times:
          aggr .1, .075 and .05 at each setting.  That's 9 total lol!  Save each full para listing and dl each log.  Look at the recoded PID's and your mec failure graph to see with one worked best.  Then load and fly : )
          • Lowered aggr to 0.05, this is what a roll and pitch axis tune gave me 0_o No more twitchiness, but still very weird that roll and pitch pids varied sooo much. Flew very well. Not as locked in as I would like, but very useable still. May increase to .075 and see what thats like. Thanks a lot guys
            https://storage.ning.com/topology/rest/1.0/file/get/3702862252?profile=original
            • Well, I find with the H frame layout and my payload in the front and batteries at the back the PID's for pitch are higher than the roll.  But not that much difference as seen in your screen shot.  I'm no expert on analyzing autotune's, but I've found with the D value is still at the default (.004), that axis failed.  Try that axis again while leaving your pitch.  If it works, do both axis again and see if it improves.  You should get better results from each iteration.  I know it bites, nothing more boring than going through autotune.  I've got a new 960mm HEX I have to do today, like watching paint dry.
          • I redid auto tune without my gimbal attached, seems like a slight improvement, but still twitchy, never thought about lowering the aggr, will charge tonight batts tonight and try early in the morning, Thanks a lot.
      • I use sunnysky v3508 580kv on 4s, will try out these settings tomorrow after work.
DIY Robocars via Twitter
Saturday
Saturday
Jun 16
Jun 13
Jun 13
Jun 13
Jun 7
Jun 7
May 28
May 15
May 14
May 13
May 13
May 11
May 8
May 8
