Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
+1. It would be very logical. we have 850, 1000 and 1200.. so that would be a very welcome "new" parameter.
Here is the log. I'll do another try on Wednesday when it should be less wind here and of course I can do another test when the next RC is out.
39.BIN
I restarted the Autotune since the quad descended really low the first two times and I didn't remember it doing that on the previous version.
Hi Maciej,
The release went out with AUTOTUNE_AGGR set to 0.05. This tends to be a little sensitive, the default should be 0.1.
I suspect we will get a lot of failed autotunes until the next release candidate because of that default value.
Thanks!!
Great, thanks for the info :-)
Loaded 3.3 today, previous 3.2.1 flies fine in PosHold but with 3.3 I got error (Flightmode err 16) and PosHold is not working
Loaded 3.2.1 back and it is rock solid in Poshold.
I did not change anything between the 2 versions
Did this (Note #1: because of the accelerometer range change (see 6b below) this upgrade will require the vehicle's accelerometer calibration to be done again.)
Log from 3.3 attached 2015-04-13 19-18-15.log
Log from 3.2.1 attached 2015-04-13 18-38-21.log
Logs zipped
I tried to upload the logs, zipped and plain but it will not work.
How to upload logs??
Tested 3.3 today using Stabilize, Position Hold, Auto and Guided.
Test was done in 20 to 25 mile per hour winds.
If it weren't for the new tones between modes and landing I wouldn't know the difference.
The Altitude is still moving around.
just a feedback...I flashed the firmware, I haven't changed anything on my setup, just the firmware. Upon flashing, I cannot control my Alexmos gimbal's pitch. The Alexmos board is connected to the Aux1 port of Pixhawk which is programmed for the tilt control. It was working on AC3.2.1 before, but after flashing, the problem was there. I reverted to AC3.2.1 and again I can control the pitch. I tried to reflash AC3.3rc1 afterwards, but the problem persists. I used to control the pitch via RC6, the Gimbal is configured before in AC3.2.1, Can you help me please?
perhaps I need to rewire my gimbal to pixhawk... Can somebody enlighten me about the serial interface? i believe I am using the PWM setup, with RC9 (Aux1) connected to the Alexmos gimbal RC_pitch..
Or it would be better if I can still use PWM for the RC pitch of the Alexmos BGC..
Anyone else having this problem?
