Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
      • Thanks for the tip!
        Found the post on page 29 and got it to work. Required a reboot but working fine just like before.
        robin
          Robin,
          Great.  I've updated Note #2 in the main part of the discussion to add the bit about the board requiring a reboot after changing the MOUNT_TYPE.  This seems to be the #1 issue people bump into with AC3.3 so we need to find a way to default that parameter to "1" if the user has been using a gimbal previously.
  • Paul / Zhang,
    Thank you for the really helpful information - when it arrives I will give it a go!
    Cheers, MIke
    • It works!
      https://youtu.be/ckY_XuoxMEU
      Several keys:
      1. orientation of the Flow module has been changed to X for forward(used to be left)
      2. there is a start-up problem with their communication, so always power the pixhawk up with USB cable, and then connect the LiPo.
      3. Do not switch from STAB into LOITER in the air, IT FLIPS!
         Just take off in LOITER!
      Hope it could be of help.
      zhang
      • Hi Zhang,
        I changed EKF_GPS_TYPE to 3, but there was the message “Pre-arm: need 3D Fix” while arming in Loiter mode. Could you attach your param list of craft?
        Thanks a lot.
        leo
      • Is switching to loiter without Flips in rc-7 now possible ?
      • Do not switch from STAB into LOITER in the air, IT FLIPS!
        What do you mean? With Flow module, or always with 3.3?
        • It's a issue with FLOW is enable and EKF_GPS_TYPE set to 3, Paul said it will be fixed in the next release.
  • Really thanks so much for your reply,
    I think the key to my problem is the range finder, I'll mount a separated sonar to my pixhawk as soon as possible.
    I have spent the whole last two days in this, watching your youtube clips and github codes. Without your kind reply, I could not even think about this aspect.
    THANKS for your contribution!
    -Zhang
    • Hi Paul,
      Do you think the onboard sonar sensor will ever be supported? I just wondered if 3DR should be informed as they are selling them still. Funnily enough the eBay far east version doesn't come with the sensor and is a fair bit cheaper.
      Hopefully I will be able to do some testing this weekend if they arrive in time! Thank for all the handwork, I think OF could be a real advantage. Cheers!
