Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
            • +1 - I also would like to have an option to disable the internal compass. I believe it would be beneficial to the system.
              • i think there is an option to disable each compass....but which one is MAG2? I find it difficult to tell if thats internal or external
                • I understand that 1 is the ext compass
    • i cant attach the log file, is too big....will figure another way
      • here is screenshot...the forum is acting weird today
        https://storage.ning.com/topology/rest/1.0/file/get/3702720778?profile=original
  • 3702100724?profile=originalHad a strange behavior during autotune in rc12, when it was autotuning the roll axis it made a pause in the tune and yawed slowly 360 degres counterclockwise and then continued with the tune of roll axis? It finished all the 3 axis.
    The autotune was OK when it was finished, tried it for about 5 minutes.
  • when will the official 3.3 be released i been waiting a long time.. i see 12 rcs
    • Kirk: you can get a try with carefull and returned to stab release if you don't like, for my last build, I have to solve some issues yet but this release is the difference to fly and no fly so no return for me.
      Remember to save your params in case you don't like it it's easy to go back..
Gremsy liked Gremsy's profile
Mar 12
DIY Robocars via Twitter
Nov 27, 2022
Nov 24, 2022
Nov 24, 2022
Nov 24, 2022
Nov 24, 2022
Nov 20, 2022
Nov 20, 2022
Nov 8, 2022
Nov 8, 2022
Oct 23, 2022
Oct 23, 2022
Oct 23, 2022
Oct 19, 2022
Oct 18, 2022
Oct 13, 2022
