Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
Thanks Leonard!
We "monocopter" enthusiasts are quite in the minority, had to ask here amongst the multidudes...
Actually, it's an asymmetric bicopter...;>)
Thanks! Will do. It is set at 10 now (default). I'll give 40 a try and report back. I'm not sure what use a log file would be but I've attached it-- just my last run tonight (just tinkering in the yard in the dark), You can see here where I was stationary in alt hold applying 100% yaw (it does several 360's), I let go of the stick and it looks like it did another 360 before resting. (well, okay... log is to large to attach, will see if I can link it from work tomorrow)
Hi Michael,
If you have done nothing else you may just need to increase the ATC_yaw_accel parameter.
No joy. (moved from 10[default] to 40 and still very sluggish and will complete a 360° or so before resting when holding full yaw (same as before). Just took it up for a quick flight to test and keep the log short. One thing I did try was to increase the ACRO_YAW_P from 4.5 to 5.5 but nothing noticeable. The current Yaw PID's are very close to the autotune values. I've just bumped them up a bit (Stab P from 3.78 to 4, P .15 to .17, etc...and the tiny bit of D had no effect either, etc... etc...)
2015-06-12 20-42-14.log
Hi Michael,
ATC_ACCEL_Y_MAX is currently set to 9000. Increase it to 27000 and see how you go.
I settled on ATC_ACCEL_Y_MAX at 36000 for my small DIY tricopter.
Possible "bug".
Problem: After running Autotune (Y axis only), the ATC_ACCEL_Y_MAX resets back to 9000. I was able to repeat the event on each of three tries. It only happens after Autotune.
in my system after initial autotune this parameter was set to 15000, after new autotune with lighter battery it got to 17000.
what is the logic behind it and what is the safe vaue range to set it to?
atc_accel_p_max is 91837, atc_accel_r_max is 132275 - so this 17352 value indeed seems a bit out of place.
or is it?
Awesome. That did it! I may bump it up a bit, but 27000 works very very very well. Thanks!!
Hi Guys. Can anyone elaborate on the autotune Aggressiveness parameter? I can´t fully understand what it would do if I set it to 0.5 (like I did by mistake) instead of 0.05. Are there any recomendations regarding frame size/type? I tried the full setting guide but there is no help there.
Thanks!
Hi Bernardo,
0.05 (5%) represents the amount the copter will overshoot when trying to achieve a rol/pitch/yaw rate. The larger this number the more aggressive the response and the closer the copter will come to being unstable. I currently let the number go from 0.05 to 0.1 but will increase that to 0.2 for experimentation purposes. Very few copters need more than 0.1 and the lower you can go the better the tune tends to be for control. The higher numbers tend to be better for rejecting external disturbances.
350
351
352
353
354
of 449 Next
