Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
          • Randy, so i've done some deeper testing today.
            I couldn't get apm anymore to run into EKF error. (Red/Yellow flashing led)
            Probably the problem was solved by re-run compassmot in a reasonable manner. This is not so simple as the motors are spinning up to 20000 rpm  and consume 160 Amps. But i think this time i've done it right. I will record it next time as the sound of motors is really impressive,
            What i noticed instead is that the throttle mid value is causing the problem. Seems that values below 300 are accepted and saved but not taking any effect. The Throttle in and Throttle out values remaining same no matter if throttle mid is set to 200 or 300. No difference. Perhaps you could look into ?
              Pomaroli,
              Ok good that things are improving.
              There's constraints in the code to protect against setting THR_MID below 300 or above 700.  It's probably not a good idea to fly a vehicle which hovers at values outside of this range because there's likely not enough range left over for proper control.
              it's mentioned on the wiki but you can check the CTUN message's ThrOut value to find out what the idea value is for your setup.  Maybe you've done that but just in case.
              • Randy,
                ok i undestand, the copter hovers on throut of about 230.
  • What does it means:
    Test: Compass = FAIL - Large change in mag_field (79.86%) Max mag field length (644.89) > recommended (550.00)
    Any hints how to solve it?
      Andrei,
      Definitely best to include a dataflash log.  We can then compare the mag field length to the throttle or current draw and if it's motor interference (which it probably is) it'll be crystal clear.
      • Attached my compassmot retults and logs.
        2015-07-25 20-00-26.zip
        • Randy, any ideas what is it?
            Andrei,
            I've had a look at the compass and compared to my IRIS.  The graph's for both vehicles are below with the magfield (in red) vs the throttle out (in blue).  There's certainly a lot more variation in your vehicle's log (top) but it doesn't seem very correlated with the throttle output (or current which is not shown) and only somewhat related to lean angle.
            I'm not seeing errors on the I2C bus, the compass remains healthy for the whole flight.  So I'm really not sure what's causing the extra noise.
            We have a slight weakness in the software in that we rely on the compass hardware's vector scaling which we know is not perfectly accurate.  We have an improved compass calibration routine coming in AC3.4 (already in Solo) that improves this.  Without this improved scaling you may find the mag-field length changes as you lean the vehicle.  You can test this by connecting with the MP, then check the Flight Data screen's Status tab, look for magfield and see if it changes as you tilt the vehicle.
            3702846777?profile=originalMy guess is that it's ok, especially if you're not seeing any kind of problems in flight although I suppose it would be nice to get to the bottom of the noise.
            • Randy, thanks for review. I have no idea how to catch the source if this noise. I'm using HMC5983 - http://goo.gl/uAS2Mx ... Any ideas how to catch it?
              I aways get error (without arming, just on ground) Error compass variance. Magfield without arming (just sitting on the ground and not moving) jumps from 716-720.
              • also, did one more test, do not arm and just rotate on the same place:
                magfield on startup: ~250
                after rotation on 360: ~500
                while rotating on 360 it jumps: 440-560
                All tests are inside room.
                After I put it on the floor magfield: ~700
                Looks very weird. Can't see any correlation between angle and magfield. Bad compass? Or maybe need to test outside?
