Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
Oh, you were replying to Julian. I though my vibes were good : )
I've been the pull down menu for vibration... Didn't even realize there was vibe x y and z on the right. These actually look awful! Like 4X worse that what Julian was showing. Are we not using the acc in the vibe pull down menu anymore? Have to find out what the clipping numbers means, but it doesn't look so good.
Shaun,
No, we don't use the MP's dataflash viewer Vibe pull down with AC3.3. I've added a request for MichaelO to update that drop-down to use the VIBE message.
How did you mount your Pixhawk?
I fixed my vibration by this omnimac anti vibration mount: http://www.thingiverse.com/thing:163472
Your log looks pretty much like mine.
http://copter.ardupilot.com/wiki/flying-arducopter/flight-modes/alt...
I am thinking that larger the prop sizes and the lower the Kv the more correction factor is needed.
I am not sure if this is a ground station or software issue, but there should be a way to simply over ride the parameter max range from the extended tuning page to allow for setups which require more correction factor than normal. Auto tune yields much higher values than allowed otherwise. If I try to to tame the auto tune results a little, the only value that can be entered is what max range allows.
I know that you can manually make changes through the full parameter tree, but that is cumbersome to say the least
+1@ Wes.
I think the dev team is trying to get EKF glitches sorted out first. (I could be wrong).
Perhaps three sets of "standards params" could exists: < 500 mm, > 500mm, and >1 metre (<19.6 inches,
> 19.6 inches and >39 inches).
Not sure but as 3dr solo, X8 -M, iris+ etc are very small frames "possibly" mainly interested by small sizes?
(again I am possibly wrong).
Henri
I updated and presto! I can up the rate PID's to .300 now!
Thank you to the responsible party!
Full parameter list doesn't seem to allow changing alt hold p value... And in extended tuning it's maxed at 1.0.
I notice some recent chatter in this thread about Tricopters, so are people testing it? I've had no feedback about my changes in this dedicated thread:
http://diydrones.com/forum/topics/ac3-3-tricopter-improvements-need...
214
215
216
217
218
of 449 Next
