Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
        • I just saw Randy's post a few posts back mentioned using Ctrl-Q while in "Install Firmware" screen on MP. I tried it just now and now I can see "APM;Copter V3.4-dev Quad"  The pop up states these are the last trunked fws, so not sure if that's the same as a beta version or not.
          • I think there is often beta that although new has had some flight time by the devs but still not known to be %100 stable. When you do the Ctrl-Q you are installed 'bleeding edge' beta... it's less tested. It might have had changes that very day and not been tested as much as normal beta. If that makes sense.
            • Sorry my typo errors. I meant I only get v3.3.3 on stable or after I select beta. Just now I tried APM P2 advanced beta but I still only get 3.3.3 in both stable or beta. I would like to try beta 3.4 but not sure I am game to use the trunked version.   What version did you get ? Also what are the pros n cons between APM P2 and MP?
              • AFAIK, the 3.4 is not in beta phase yet.
                That's why it isn't showing in beta releases.
                You can use the 3.4 dev with Ctrl-Q in MP and test it but as it is still changed by the devs, you could get a stable version on day and a buggy one on the other, so use it on your own risk.
              • I have been running 3.4 dev without issue.  APM P2 and MP are very similar. I haven't used MP in a long time as my PC bit the big one but as I recall MP had a few more options. I have often seen post of screen dumps of reading logs and it seems like MP showed warnings or errors in the log I haven't been able to duplicate in APM P2 although it might be user error on my part.
                Also... I recall just recently Randy mentioned sometimes it might say one version you are installing but it's actually the newer version. Sometimes MP or APM P2 hasn't been updated as fast as the dev copter firmware so it shows the wrong version however if you look at the message screen while your controller is booting up you can see what version you actually installed. BTW the only reason I have been flying 3.4 is because it has boat mode aka it will arm even if it's moving a bit. I don't really recall what other features 3.4 has.
  • Randy,when can we expect 3.4 in mission planer....is this thread dead or what(no post for 7 days),do i need to follow whats new somewhere else?
      We are behind on Copter-3.4 and many of us (including me) are scrambling to find new sponsors which is adding to the delay.  Still, we're making progress towards Copter-3.4 but a number of features will be pushed to Copter-3.5 (instead of holding up Copter-3.4).
      The last three things we're planning to do before pushing out Copter-3.4 for beta testing are:
          - motor library refactoring (only brings minor improvements but greatly improves code structure).  This is nearly done.
          - terrain following for auto missions and RTL.  I hope to produce a video soon showing this off.
          - one-shot support.
      • Do we get same features as Arduplane 3.5.0 released on 30th January 2016?
        https://github.com/diydrones/ardupilot/blob/master/ArduPlane/releas...
        ...Can we use 3.4?  I forgot what is magic combination of keyboard buttons for that?
        Where can we give donations to make things rolling on?!
        Randy,something is terribly wrong if you and other core developers need to scratch your head for sponsors..instead being paid in millions now with regular salary....
        Chris Anderson;in my country we call this treason!No,High Treason!
          The magic combination is Ctrl-Q from the MP's install firmware screen.  Just be careful though because we're going to push in the motors library changes in a couple of days and master could be unstable for a bit.  .. basically I'm just saying it's use at your own risk.
          We're going to be setting up a donate button on ardupilot.com in the near-ish future.
          Thanks very much for the vote of confidence!  I wouldn't blame ChrisA and 3DR too much, both have been a huge help to Ardupilot up until now.  Things change, we just need to move on.
          • I would be more than happy to donate $100 from time to time. Also now that 3DR is not supporting the developer as much, is it possible to also open a DIYDrones hardware store and the proceeds of the profits of sales can contribute to the further development?
