Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
    • I'm also using an m8n, and have similar results..  Even with very low hdop, 10-20 satellites, the copter drifts around about 10 meters.  I can take a screenshot of mission planner if anyone is interested.  Copter sitting stationary on the ground, and mission planner thinks I'm constantly moving ~.5 meters per second, all over my yard.
      I have not used this GPS with anything before 3.3, so don't know if it's the cause.
      I had a different copter that I sold a few moths ago, with the lea-6 gps and older arducopter firmware, and it moved around a couple of meters, only about .1 meter per second (again, sitting stationary and just looking at mission planner).  So, the m8n, while getting many more satellites and lower HDOP, drifts around a lot more.
      There seems to be nothing telling it, if its location suddenly jumps over 5 or 10 meters that it must be an error..   The copter tries to go to the new GPS coordinates.
      I found threads from a few months ago saying the m8n isn't actually supported yet, so we're all on our own trying it.  Arducopter progresses quickly, though, so I'm not sure if it's supposed to be working now....
      Should we have good stable results w/ the m8n, or is it still experimental?
      • This reply was deleted.
        • My one is from drotek, so it's not the cheapest and nastiest, and it's been manually configured for 5hz, airborne 4g. I can just see this as causing serious issues when coming in to land, as often there are trees blocking the view on one side of the copter, and I can't afford it to take a dive into them or something else if the lock degrades slightly as it comes past them. Surely there's a way to tighten the EKF glitch filter to deal with these cases better?
          • Mine's from Drotek too, I have both the normal size and the XL, although I'm yet to finish my build using the XL. I'd read that the 8 series were sensitive so I've done the whole, copper shielding and earthing. Done the same as you by manually configuring it too.
            One of the fields I test in I'm close to a large hedge and some trees and have had very successful RTL's...the only issues I have with landing is the throttle not cutting quickly enough.
            I had read that the 8 series works better in Europe than in the US, but whether that's just rumour or provable, I don't know?!
            • You mind making a copy of your M8N parameters with ublox u-center and share it with me please ?
              Cause I've made some changes to my two units, namely SBAS, NAV5, refresh rate settings and now even using the 'reset to default values', makes my quad fly away as soon as I engage any GPS dependant mode (and hdop / num of sats is good and doesnt vary too much)
              • This setup works very well in my Drotek xl and CSG
                3702908948?profile=original
              • M8N config
                • Sorry Leon, but the .ubx file didnt work out.
                  You need to save it as .txt (ublox ucenter , menu tools -> GNSS Configuration -> GNSS to file
                  please
              • Will do (once I get in to work ;) )
        • I agree that they vary in quality. I've had a very bad one and my current one (RCTimer) is excellent.
          I suspect the drift is down to the velocity noise which is supposed to be worse on these units. I think well designed attennas make a difference here, but net is that with patchy coverage performance will be worse than some of the older units.
          YMMV :)
          • I can corroborate good experience with the RCTimer M8N. In fact I just ordered a few more. cheers.
            Rctimer NEO-M8N GPS & MAG(Compass) V2.1_Rctimer R/C Hobby Online Shop
            Rctimer NEO-M8N GPS & MAG(Compass) V2.1现价39.990; M8N Tutorials:  Multi Constellation GPS (
