Copter-3.3 beta testing
Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
              • I can propose to test the following parameters:
                Stabilize Roll 8, Stabilize Pitch 6, Stabilize Yaw 4.5
                Keep the Rate Roll and Pitch PIDs from the last autotune.
                Put Rate Roll/Pitch both Imax 1000,
                Rate Yaw P 0.2; I 0.02; D 0
                • Thanks for your help.
                  Had crazy week, but did some testings today.
                  Lowered settings and i'm now vibrations are gone.
                  still need to retune the system to better stabilization.
  • This reply was deleted.
    • Pids are not bad, but stabilize pitch/roll params are usually not more 8. You can try manually 5; 6; 7 etc.
      The reason for Yaw and throttle height variations is bad barometer ventilation. .Will be good to send picture of the copter and the Pixhawk position.
      It is important to make the barometer damping with dense polyurethane, proposed by Marco and I posted here:
      http://diydrones.com/forum/topics/upgrade-to-3-3-2-alt-hold-rising-...
      Then should avoid the air stream from the propellers direct to the controller - can try kind of windshield, box with some side holes only or similar. When launching / landing the air pressure area below the copter can cause jumping, if barometer not damped.
  • I am so pumped for 3.4......
  • Is it possible that the latest firmware reports things like "bad gyro health" more often?  Sounds funny, but I've been getting this message sometimes during flight or just hooked up to the computer making param changes.  No effect of flying so far.  I had two previous Pixhacks with this error, but they didn't clear and had to be returned.  One of the Pixhawks actually crashed.  I was under the impression it was definitely a hardware issue.  Should this autopilot be retired?  The message has shown up 3 times this week.
      That error can appear for a few reasons so it's hard to be sure but if it only appears soon after startup then I wouldn't worry too much.  If it's appearing in flight then I would worry and would probably replace the board.  Looking at a dataflash log and checking the IMU messages's final two fields (AccHl, GyrHl I think) which have the accelerometer and gyro health would be good.  If it's changing between healthy and unhealthy or one of them is always unhealthy then it's most likely a hardware issue.
      • I'm a bit confused lol.  Do you mean AcHlt and GyHlt?  If that's the one, I'm getting a drop from 1 to 0 on GyHlt from IMU2 every few flights.  Also, anyone know what this "ERR: 195-129" is?
        • Can't remember where I heard it or if its true, but something about the gyro does an internal calibration on power up and if the copter gets jostled during this time (like plugging in a xt60 main battery connector) it can throw this error. This would be different than the flashing red/blue partway through the pixhawk boot. Again not sure if accurate, maybe someone with the hardware knowledge can chime in.
        • Black Sheep (who I bought the pixhack from) says it interference...  Really?  Not the best answer.
      • ok, thanks for your comment :)
        Is it enough to have the LOG_BITMAPS = 958 to see that later in the dataflash log? (Pixhawk)
