Changes from 3.3:
Changes from 3.3-rc11:
Changes from 3.3-rc10:
Changes from 3.3-rc9
1) EKF improvements:
3) Safety:
Thanks for your testing!
Craig, That picture you uploaded was the exact same error that mine gave me after a failed firmware upload. The Px4uploader was able to send the data regardless. The device descriptor not loading is not something that will cause the upload to fail. Windows recognizes a device is plugged into port X but it just doesn't know what to call it.
unfortunately it seems now the hardware has failed as windows no longer detects a usb device at all and the px4 lights blink red/blue but the imu lights just kind of flicker.
I'm just going to return the board sigh.
Thanks for the help.
Did you try on another pc?
Yup. but no worries. I tried the SD card out of my other hawk. I tried booting holding the safety switch. I tried different computers, different usb cables, and different hubs and what not. Just waiting on the RMA to send it back and be done with it and will start again when he replacement gets here.
Ups!! , it's horrible when you can't find a solution; at first I reset to default as you, but what I do now when I want to reset settings, I use reset to default button as Randy recommends; first i save old settings and them I use compare button and check only modes, batteries and that standard settings not to have to program all again...vague woman ;) , perhaps this helps the following time you want to reset settings.
Well my solution was my vendor is sending me a new board without even having to send the old board back.
I really do not think the old board is salvageable though. I took the board out of the case and while I was trying a FTDI a part on the board got so hot it burned my finger so whilst inititally it seemed it was simply a software issue, it soon became a hardware issue as the IMU lights no longer come on [except for one flickering really dimly] and windows no longer sees the com/usb port at all.
Just glad all this happened on the bench and not in the air :)
Try this. Connect the USB cable to the PC and to pixhawk, at the same time connect to the port telemetry, programmer ftdi. In this way saved their fc, despite the lack of detection by USB, fc was detected by FTDI and fw be received any fc came to life. You need to check what port you will have to choose, I do not remember if I picked com usb or com ftdi
I had similar issue couple of times when sd card would lose connection and no usb device would appear in windows.
Having an unusual issue with all motors spiking in throttle after SECOND arming event. The problem goes as follows.
- Quad plugged in.
- All Pre-arm checks passed
- Arm Safety switch depressed
- Quad armed via Tx and flown with no issue
- Land and disarm via Tx (Without depressing Arm safety switch. Switch remains illuminated as steady red)
- Immediately after arming again all motors spike to 50% power.
- When Tx throttle moved slightly above low point and quickly back to low all motors respond as expected and I am able to takeoff from there without any problems.
Any subsequent attempts to takeoff following the above sequence repeats the problem continuously. If i unplug everything and then start from step 1, the first takeoff is always as expected. The problem only occurs on the second takeoff event as described. The included photo is from the log file showing a graph of my throttle input to capture the motor runaway and bring them back to low for normal takeoff. This problem presents itself regardless of the flight mode used during takeoff. Acro and Stabilize
Ps: Previous issue with stability solved. Quad gimbal flex was causing High frequency oscillations (above what pixhawk can measure?). Auotune did its job and provided the highest PID possible while minimizing issues. Once the Gimbal twisting issue was solved autotune PID's provide a rock solid multi-rotor. Excellent job guys.
Maury,
Thanks for the report. It looks like you've downloaded the dataflash logs, could you post them here as well?
254
255
256
257
258
of 449 Next
