Damaged APM, I messed up
While soldering the pads on a new APM (the 3 filter pads) my soldering iron slipped and dislodged a surface mount component. I thought i would be able to repaid this, i was wrong.
Please see the attached photo. The blue arrow points to the component that is no longer on my board. How do i find out what this component was and get assistance fixing this?
Any help or advice appreciated.
  • Thanks a ton Gerard. Either way, looks like a simple fix.
  • Sorry, yes your card is REV H V10 Hotel found here :
    http://diydrones.com/profiles/blog/show?id=705844%3ABlogPost%3A2005...
    The pad was for enable/disable gyro low pass filters
  • After looking at close ups of the traces on the board that with that component missing it is the same as not having the z gyro pads not soldered. So i guess it could be worse.
  • Thanks Gerard. Those don't seem to be for the Rev H board (new board) which is what i have. It does not show the pads or that component.
    And yeah Lee, tiny. I had control of it for a mere 5 seconds before it was gone.
  • That same thing happened to me! Except my iron didn't slip, just the heat from soldering the pads was enough to dislodge that component. The piece is tiny, I almost lost it as well, but was able to finally manage to solder it back on. At least I think so.... Goog luck!
    Lee
  • You can find schematic from the store :
    http://store.diydrones.com/product_p/br-0013-01.htm
    The component is C2 : 0.1uF
