Differential Ailerons not working in ArduPlane v 2.26
Just curious if anyone else is having this problem.
I tried upgrading to Ardu Plane v2.26 and my differential ailerons are not working in stability, FBW or Auto modes. I still have manual control, but if i flip to stability mode and roll the aircraft, only the aileron on channel 1 will react. I have RC_CH5 = 1 in my configuration file. They worked no problem in 2.24.
Anyone else notice this?
  • Bryan,
    The number for the program a differential Aileron channel has changed. The related code is now in RC_Channel_aux.cpp. THis whole area of code seems to have been significantly changes from 24-->26
    You now need RC_CH5 =4 for the second aileron.
    Here are all the codes. I do not know what most of them mean, and as far as I know the Wiki has not been updated to reflect these changes.
      k_none   = 0, // disabled
      k_manual  = 1, // manual, just pass-thru the RC in signal
      k_flap   = 2, // flap
      k_flap_auto  = 3, // flap automated
      k_aileron  = 4, // aileron
      k_flaperon  = 5, // flaperon (flaps and aileron combined, needs two independent servos one for each wing)
      k_mount_yaw  = 6, // mount yaw (pan)
      k_mount_pitch = 7, // mount pitch (tilt)
      k_mount_roll = 8, // mount roll
      k_mount_open = 9, // mount open (deploy) / close (retract)
