I want to be able to switch a digital pin on the APM2.5 without use of the R/C radio. I was thinking a simple script might be able to do this? If not what would be required to have this as a function for use through a telem system during a mission?
Thanks!
You should be able to do it with the DO_SET_RELAY command but the pin would be hardcoded. I also don't know if it works on arduplane.
Thanks, looks like i'll go custom firmware or build a servo switch. Just wanted to double check there was not an easy way I was missing.
