Can anyone suggest a fix for this, I was running matrixpilot 2.02 and had to modify the options.file to work with 3 channels, elevator, rudder, throttle. All worked fine, then I edited the options file as I had left ailerons still enabled and now the ESC is telling me there is an abnormal servo input. It works absolutely fine straight from the Rx. I have the channel reversed on the Tx and have tried the software reversal in options.h but I am getting nowhere. My next step was to 'scope the o/p on ch3 from the UDB.
Any suggestions welcomed, the option file is attached
I'm not sure what 4 pin connector your referring to, but for something expendable like a connector, just cut the pins, and remove them one at a time. That's what I'd do with the gyros where possible. Solder wick, dipped in flux paste removes the solder pretty easily.
If you're working with something that requires multiple pins to be heated at once, a hot air rework station is the way to go. With solder paste, and a hot air station, even changing the CPU isn't all that hard to do.
I'm wondering, is the UAVDevBoard suitable for Quadcopter-project. The plan is to make it fully autonomous, but with the upgrade possibility to use radio to control the machine in the future. I have a few questions that I need answers to move on. I think this is the forum where is the best ackowledge:
2. There is four motors in quadcopter, in the DevBoard is only three Servo connections. Is there any spare pins that I can use for the fourth motor?
3. Is it ok to connect one or two parallel 3 Cell LiPo batteries(11,1V) to all four ESCs and then connect all control lines of the ESCs to the servo pins in the UAVBoard?
4. If I understood correct, the ESC gives about 5V through BEC, so there is no danger of noise that comes from the motor and ESC? The Board should be working good?
5. The PWM pulse for the ESC should be 8kHz. Servos are controlled usually with 50Hz frequency. Can I increase the PWM output to 8kHz?
6. If I want to upgrade my UAV with CameraCntlr and telemetry link, will I run out of pins on the Board? :P
There is a lot of questions and I know that I need to code almost a new autopilot, but this is a long project, a hobby that I'm willing to use time :)
The Matrixnav 2 version is working on an EasyStar? (just rudder, no ailerons)
I like to use it together with the remzibi osd, similar way then the existing Ardupilot integration. It requires some additional features, so I have some program code questions.
- Is there some code version similar to the Ardupilot-remzibiOSD integration?
In detail:
- the osd requires nmea serial input, so my first question if this code version is working in nmea mode?
- the osd is working as display for messages like "manual mode", "stabilized mode", "waypoint 1" etc. It receives these messages on the same serial port as the nmea sentences. So the best solution if the devboard echoes the nmea sentences to the serial output and inserts the messages as well. My question if there is a sample code for echoing nmea sentences?
- the current serial speed setting is low, what happens if I set it higher? (because an additional message requirires some extra time between the nmea sentences) Are there possible timing problems?
- if the devboard is working in a different mode (binary or uBlox), is there a "translation to nmea" (for the output stream) code sample available?
I am familiar with embedded programming, however don't like to re-invent the wheel and working on code that maybe already available...
Another MPLAB problem, I'm afraid. I can program the board fine on an old Vista machine, but when I try to program it in an XP compatibility window (virtual XP mode) in Windows 7, I get the following error. I think everything else is identical to my Vista install. What am I doing wrong?
I am interested in autonomous flight, and have a project in mind which, with some help from other members of my local R/C club, I hope to implement in the long term. I've been investigating various hardware options (Ardupilot, etc) and the UAV board is very impressive.
I live on a small Caribbean island. My friends and I would like to design and build an aircraft which, after local testing, can carry out the following "missions":
1) Fly cross-country, from one end of the island to the other, a distance of ~35 kilometers. This would require some sort of RTH feature where H = Home and Home != Launch.
2) Circumnavigate the island, a distance of ~90 kilometers, then RTL.
3) Fly over the ocean, from a launch-point on our nearest island neighbour, to a predetermined landing point here, a flight of ~250 kilometers. Similar to #1, but involving a greater distance.
During the flight we would like to accumulate data including photographs/video for recovery and examination upon landing. Telemetry would be nice, if the distances don't make it impractical. The local regulatory body for aviation has expressed enthusiasm for such a project.
With appropriate software development, would the UAV board be suitable? I read that there was a 30 mile limit on flight range due to the use of 16-bit values in the navigation code. Is this set in stone? Also, if I understand it correctly, should the system lose contact with the transmitter on the ground, it switches automatically to the RTL mission profile. (Or am I completely mistaken about this?) For longer flights we would need the aircraft to fly the middle part of the mission without any signal from a ground-based transmitter.
Finally, all that I've read has shown the board being used with a Windows environment for development. I use Linux, and have no Windows computers. Is it possible to use the UAV board in a Linux environment?
Guys, when you're using the uBlox 5 GPS, does it use the ArduPilot settings? When you buy the module from the DIY Drones store, you have to choose whether to have it programmed as "Paparazzi ready", "ArduPilot ready" or "NMEA (default factory settings)". Which should we choose?
I'm afraid I'm struggling with PIC programming again. When I make the project, I get this warning for every file:
Microchip MPLAB C30 License Manager Version v3_20 (Build Date Aug 24 2009).
Copyright (c) 2008 Microchip Technology Inc. All rights reserved.
The MPLAB C30 license has expired.
Options have been disabled due to expired license
Visit http://www.microchip.com/ to purchase a new key.
I'm having trouble getting the MPLab IDE to recognize the Olimex ICD2 programmer under Windows 7. Apparently it doesn't have a driver for this. Anybody get the ICD2 to work with Windows 7?
regards
chris
options.h
Rusty
If its not too late I would like to see one with flat gyros, and more R/C inputs and ouputs.
Keep up the good work.
1. I should use the Boards servo connections to control motors. Is it possible to connect this kind of ESC to the servo pins: http://www.headsuprc.com/servlet/the-1413/20A-POWER-UP-Brushless/De...
QU
In detail:
Thanks,
Comments, please. Am I barking up the wrong tree?
The final reading is:
Program Memory [Origin = 0x100, Length = 0x7f00]
section address length (PC units) length (bytes) (dec)
.text 0x100 0x1e9e 0x2ded (11757)
.const 0x1f9e 0x1ce 0x2b5 (693)
.text 0x216c 0xcea 0x135f (4959)
.dinit 0x2e56 0x1f6 0x2f1 (753)
.text 0x304c 0xf3c 0x16da (5850)
.isr 0x3f88 0x2 0x3 (3)
Total program memory used (bytes): 0x5dcf (24015) 49%
Did it just write a bunch of zeros? I have the evaluation version of MPLAB, so it shouldn't be complaining about the lack of licence.
[you can see why we picked Atmel and Arduino for ArduPilot!]
2
3
4
5
6
of 11 Next
