DIY 350mm quadcopter
Hello and thank you for allow me to share my experiences with you. I am selecting my components and it's my first quadcopter. After some research I have the following components:
Frame 330mm: (160g)
Propellers 8045
Motor 2212 1400kv (192g)
ESC 30Amp Readytosky (100g)
Flight Controller Naze 32 (10g)
Power distribution board Blusky with XT60 (10g)
Battery 11.1v 3s 30c(191g)
Flysky FSi6S with iA6B
After complete the same calculus in this tutorial...the flight time is 13 minutes and I think that is very short according with the frame and propellers size. Could you please tell me how can improve the flight time?, I don't know if I can use propellers 9040 or even is this will improve the drone.
  • 13 minutes is not that bad! Is that hovering around or boring holes in the sky? What cutoff voltage are you using? The best way to get more flight time is to use a bigger battery if you are OK with flight behavior. Your quad's weight is so low that another 100g spent on battery would make a big difference, (25%+ more flight time). Next thing to note is that at this weight your motor KVs are too high for these props. They are only turning at around 4500 rpm at hover, (I checked their thrust v RPM graph). A 9" prop would be slightly more efficient but an even worse match with your motors and would require a motor with a KV around 1000.
    • THanks Ian, I was looking for a bigger propellers and different motors but after looking some graphics or tables likes this:
      https://quadquestions.com/blog/2017/02/22/choose-right-size-motors-...
      I seems that for the frame (330mm) the max size for propellers is 8" and even in the site where I am buying the frame, they recommend 8". So my question is: Is there a way to know if I can change the propellers to 9" without crash the drone? In that case, 9050 is ok?, so it's suppose that I can use motors 2216 with 1000kv?
      How to choose the right size motors & ESCs for your Drone, quadcopter, or Multirotor build
      • Check if 9" props will overlap on this frame. If you are forced to say with 8" then I would suggest using 2212 motors with the 8" props which will save about 60 grams towards that larger battery. Stay with 1400kv with the 8" props. Last thing is to try a 4S battery of the appropriate weight if your ESCs can handle 4S. My suggestion for your next quad would be to us DJI Phantom 4 pro quick release prop motors and 9.45" quick release props. You can buy these as repair parts quite cheaply on line. With a 5000mAh 4S battery an 1100gram quad will fly for close to 30 minutes, (just like a Phantom 4 Pro)
  • Naze32 is good "obsolete" control card.
    Rule of thumb weight:
    1/4 frame and accessories,
    1/4 motors and esc and propellers
    1/4 battery
    1/4 payload (cam, gimbal, video tx,...)
DIY Robocars via Twitter
RT @DWalmroth: Weather's finally cooperating, looking forward to racing 1:10 scale autonomous cars outdoors again! @diyrobocars, @NVIDIAEm…
Wednesday
RT @AIDRI_: I finally succeeded in optimizing the trajectory and speed of a car on a #racetrack. Next step: implement a 2d controller and…
Wednesday
@jetdillo @circuitlaunch Actually the second *in person* event in a year. We do virtual races every month
Apr 2
Update: we're moving it back one day to Sunday (the 4th) at 11:00am instead
Apr 2
@GrantEMoe @circuitlaunch Update: we're doing it on Sunday (4th) at 11:00am instead
Apr 2
Laurie J. Troy liked Jasper Kueppers's profile
Apr 1
RT @chr1sa: Maybe we should have a mini @DIYRobocars race in our lower school's playground https://t.co/xLFeua1R6X
Mar 29
If anybody wants to join us for an informal outdoors hack/race we're going to be meeting at the @CircuitLaunch park… https://twitter.com/i/web/status/1375907409223249923
Mar 27
RT @SmallpixelCar: Ready to reopen, innovation has to continue. Inside/outside, LiDAR/GPS, race/delivery https://t.co/jpmvttoHEd
Mar 26
DIY Drones via Twitter
RT @DAVGtech: By far best race yet! Congratulations to the winner @Heavy02011 🥇🏆🍾👏👏👏 @diyrobocars @donkey_car @NVIDIAEmbedded https://t.co/…
Mar 20
RT @Heavy02011: #VirtualRaceLeague: @DIYRobocars Race #8 - #ParkingLotNerds ⁦@DAVGtech⁩ ⁦@DWalmroth⁩ ⁦@OttawaAVGroup⁩ - join us tomorrow h…
Mar 20
RT @mrpollo: 11 years ago, the pxIMU was announced to the world on @DIYDrones, and it changed the life of many (mine included). The followi…
Mar 18
RT @ishcahealth: This is awesome! ☘️ @DroneDJ @DIYDrones @WorkerDrones @DroneMedia_UK @dublinaviation https://twitter.com/media_ireland/status/1372077878536462336
Mar 18
RT @DAVGtech: Changing the game, now with a Lidar. All in a virtual environment and free to anyone. #VirtualRacimgLeague @diyrobocars https…
Mar 18
Great video from UCSD students telling their @donkey_car racing story https://www.youtube.com/watch?v=M4uVoQAyt5s
Mar 18
Timothy Miller liked Joseph Udofia's profile
Mar 18
