Skycat parachute launcher for Drones
Dear reader,
We are now live at www.skycat.pro. The development project continues, and updates are added to this blog in random intervals.
We have parachutes launchers available in many weight ranges; optimal 1 - 6 kg and these could be extended with higher impact level up to 11 kg. For larger up to 23 kg multicopters we have XL - series with pilot chute principle.
For those who wants to digest all information available of products, we have left this blog as it is. This blog follows closely main steps we have gone through while developing parachute launcher. Blog might feel like Do It Yourself kind and to be honest, in the beginning it was.
After hundreds of hours thinking, designing, prototyping and testing our patent pending launcher turned to be the most reliable parachute launcher for professional use. We have searched all possible boundaries of technology and from this blog you'll find results of these successful tests but also not so successful tests.
You never know where The final limit of technology is without experiencing it. That's the reason why we have done tests for scenarios which might not be even realistic on flight.
For production versions of Skycat we could proudly to say that we have experienced zero mishaps, never failed a single eject and parachute has deployed every time. This includes rescue scenarios with every imaginable scenario copter could face in air. Check this out as one sample of our test sessions!
Skycat parachute launcher has been tested beyond all imaginable abuses copter possibly could experience in flight. We have sink it to water, it has been heated hours to 90°C and exposed to extensive moisture, we have frosted, defrosted and frosted it again, it has been in mud and snow and still it has worked. Same overshooting tests we have done also for electronics. This is not promise you can use our products outside of submarine but we have tested it so :)
This blog will still be updated as well our Facebook pages www.facebook.com/skycat.pro and Twitter at https://twitter.com/skycatpro
Fly safe - Let's keep our copters flying!
Henri
Skycat.pro
 3691048063?profile=original
DJI Inspire 1 / Skycat X55-CF parachute integration by www.remotevision.ch:
3691048138?profile=original
3691047900?profile=original
3691048089?profile=original
3691048166?profile=original
3691048255?profile=original
Other documentary videos:
Skycat Twin test session
OPENTX for parachute eject and 6POS switch
DUAL spring loaded switches - single RC channel for parachute eject, OPENTX
Brake enabled SimonK firmware
Ground eject demonstration in slow motion
Water test
Aerial test No 2 for Opale Paramodels 2.5m^2 parachute
Aerial test No 1 Opale Paramodels 1.8m^2 parachute
A moment of deploy
Tower test 3
Tower test 2
Manufacturers contributed to this project:
- http://www.opale-paramodels.com/
http://www.fruitychutes.com
- www.vectorheli.com
- www.3drobotics.com
  • Here is a video of one ordinary test session. First one is X48-CF ejected from full speed and very low altitude. Basically it acted as brake parachute.
    Another eject is XL84 installed on DSLR carrier hexarotor. Descent speed looks like unrealistic slow. Theoretically impact speed should be around 3.4 m/s but that looked even slower. Perhaps pilot chute gave some additional drag.
    • Hi Henri, that first video was wild!
      On the second one because of the very cold air your effective Cd may be very high, approaching 3.  I've seen this in my own testing on cold days.  Also the smaller "pilot" chute can also slow it some.  So you have a IFC-84-SR for the large main.  What is the smaller chute model?  That looks like one of our's as well.   Is that a IFC-36-SL?
      Great stuff!!
      -Gene
      Fruity CHutes
      • Smaller chute is IFC-48-S. It was standard package from store.
        Temperature really affects quite a lot. Air mass density increases from 1.204 / +20°C to 1,395 / -20°C and it has linear effect to drag. We have used lower 1.204 for all values represented.
        So, warm air might cause thermaling which has great effect for drag and cold air has higher density which also effects drag. Win - Win case.
        Our closest test area on own yard is surrounded by trees from west-north-east and has open field to south. It causes sometimes very strong down flow (downdraft correct term?) and it seems that parachute has no drag at all. And suddenly close to trees parachute catches up flow and almost stops. We are playing with so slow descent speeds that even smallest change on climate has effect and especially thermal might slow descent speed easily to half.
        • Yup, all very good assumptions Henri!
          -Gene
  • It's a long time since last update. All kind of projects has kept us busy and some results of those are seen today publicly in our store. Those which are not allowed to publish flies commercially / on test phase at various locations around the Globe.
    Latest addition to our portfolio is new launcher to smaller end; X48-CF. It is ideal for 2 - 3 kg multicopter and can be extended even higher weights. Video under is shot from our winter test session. This area is a lake near our workshop and it has 5 km free space to test parachutes without need of ladders for picking copter from tree :)
    We also have few third party devices here at test and development. We'll publish more about them during spring 2016 period. If you have an idea or product you think we should know or have in our store and perhaps even participate R&D, do not hesitate to contact us!
    Pixhawk has been in air several times with automatic eject enabled and so far not a single failures has occurred.
    Henri
    www.skycat.pro
  • Here is the video of an emergency situation which Pixhawk controlled all the way automatically and ejected parachute. All we did was motor failure using RC controlled relay to cut power of the motor:
      Beautiful video.  I've put at the top of the parachute wiki page (replacing one of your earlier videos).
      • Thanks Randy!
        Here are logs of four ejects; two manual and two automatic. Unarm seems to stop logging just when things becomes interesting.
        This video is a ground view of the eject. Copter total weight was 3.4 kg. On this video whole process is fully seen including ground impact.
        Youtube makes video very poor quality, here is downloadable original video 1st Pixhawk automatic parachute recovery - ground view (download it to PC for full resolution).
        logs.zip
          Thanks for the logs.
          Yes, there's an item on the to-do list to keep logging if the disarm is caused by a parachute release.
          The vehicle falls quite far before the parachute deploys.  I wonder if we need to try and force that earlier in the software or is the delay mostly in the deployment mechanism?
          • Randy,
            When logging is available we could analyze better where delay is. Now we need to estimate delay based on video.
            I made video analyze frame by frame and found overall delay to be 1.35 - 1.45 seconds from moment when copter is clearly flipped sideways to moment when parachute package is on the way to out. Unfortunately on that moment copter has good speed towards the ground and travels some meters before parachute is fully deployed.
            Another video where we ejected using Pixhawk manual eject command delay was about 0.8 seconds from a moment when pilot said "now" to moment when parachute was visible out of the tube. This is very rough estimation, or almost a guess, but still consistent with automatic eject delay.
            Eject delay with this setup is very low, 0.08 - 0.2 seconds from the moment when release is activated. This is the time which can be seen on oscilloscope. Here is minimum battery we have used; NanoTech 3S 350mAh 65-130C at rest voltage 11.96V and delay was 224ms.
            3702851546?profile=original
            After this delay parachute is on the way out of the tube and traveling takes some fractions of the second also. Here is one video where delay can be seen in air:
            1.4 seconds is long time to fall and should be shorter but only in case when we don't increase the risk of false eject.
            Feel free to make test code and we try it at our own risk. Even wilder test codes are ok for us and we have a methods to take copter down safely what ever it does.
            Henri
            www.skycat.pro
            Skycat.pro's post on Vine
DIY Robocars via Twitter
May 15
May 14
May 13
May 13
May 11
May 8
May 8
RT @SmallpixelCar: Test my car. RTK GPS worked great. Thanks @emlid for their support. https://t.co/EkQ6qmjmWR
May 8
DIY Drones via Twitter
RT @chr1sa: @kane That's @diydrones circa 2009. Still have a box of those Canon cameras that we used to strap into planes, just like this.…
May 3
RT @chr1sa: Our next @diyrobocars race is going to be outside at a real RC racetrack in Fremont on May 28. Fully autonomous racing, head-to…
Apr 30
RT @f1tenth: Our Spring 2022 F1TENTH course @PennEngineers is coming to an end with a head-to-head race as a big finale. So proud of our st…
Apr 26
RT @DanielChiaJH: I wrote a thing! Throughout the development of my @diyrobocars car I've been using @foxglovedev Studio to visualize and d…
Apr 23
RT @SmallpixelCar: My new car for high speed. Low body, everything ( @NVIDIAEmbedded Jetson Xavier NX, @emlid RTK GPS, IMC) under the deck…
Apr 23
Apr 21
RT @f1tenth: F1TENTH Race training setup @PennEngineers for our upcoming ICRA2022 @ieee_ras_icra competition. @OpenRoboticsOrg @IndyAChalle…
Apr 21
RT @fatcatFABLAB: Proud to be hosting a restarted DIY Robocars NYC Meetup April 26. Come by if you want to talk about and race self-driving…
Apr 17
