DJI E600 escs not working right
I have been reading you do not need to calibrate dji opto escs and after installing cannot get them to work properly.
I am trying e600 escs which plug directly into the power distribution board.
I did try to do a calibration after it failed to work and was able to get all motors spinning in calibration mode however when I unplug the battery it is like it forgets about the escs all together and the escs goes back into a lot of beeping when I arm.
Clear the card on the pix and setup and now working right!
  • esc-s beeping still you press safety button.
    this is normal
    • The escs beep when I start every second or 2. This press and hold safety button and they beep faster.  Motors do not spin
