Do you threadlock your prop nuts?
I'm new to the 3DR multirotors and their shaft setups, but I've already lost 2 props due to prop nuts becoming unfastened in flight.  Neither led to a crash (thanks to the Y6's redundancy), but after the last one I was unable to find the prop nut.
I crank them down as much as possible using a small allen key for leverage, but can only get so tight because it's tough to get a grip on a round motor.  Do you guys use threadlock to keep your prop nuts on?
  • I love how the usefull information come months after it was needed
    • I find old threads VERY useful. It is called "Search"  When one knows how to do searches with well chosen key words answers are found in mere seconds.
  • I use "nyloc" nuts and without threadlock of course. I'm also changing nuts to new after 4-5 times opening. This habit comes from working with fullsize airplanes and copters....
    Regards
    Jani
      Another point to remember about thread-loc, is that its dangerous to use with glass filled nylon parts.
      I learnt the hard way when I noticed dozens of spider cracks around every screw on my helicopter frame after using Loctite.
  • You said..
    Are your prop nuts collet type or the newer later style that with the threaded stud above the prop hub like THIS ?
    If collet type, there are some precautions to use. If the later style, try holding the prob hub while tightening rather than the motor housing...threadlocker won't hurt either.
    -=Doug
  • Yes. Learned the hard way. Sometimes you just forget to check them before launching.
  • unlike andrew I do recommend theadlock, then again I have only flown fixed wing. I have also had no issue getting the nut off afterwards or if you still don't like the idea of  a CA a nylock nut will be the next best option
  • No but I check them every couple of flights as part of my preflight. Use regular hex nuts instead of the pretty cone shaped nuts if your concerned.
    • I now thread lock using the Blue. With wood props I still have to double check in case they swell or shrink. Blue allows you to be able to remove later.
Joseph Udofia liked Joseph Udofia's profile
Wednesday
DIY Robocars via Twitter
Jan 28
RT @Heavy02011: ⁦@diyrobocars⁩ : A Home-brew computer club* for Connected Autonomous Driving. talk at #piandmore ⁦@PiAndMore⁩ on Jan 23rd h…
Jan 23
RT @a1k0n: New blog post! Deep dive into my ceiling light based localization algorithm which runs in 1ms on a Raspberry Pi 3: https://t.co/…
Jan 23
Great new guide to using @donkey_car https://custom-build-robots.com/donkey-car-e-book-en
Jan 23
RT @chr1sa: The next @DIYRobocars virtual AI race is tomorrow morn at 9:00am PT. You can watch live on Twitch https://www.meetup.com/DIYRobocars/events/275268196/
Jan 22
New version of Intel OpenBot! This resolves many of the issues with the first version, including a much smoother tr… https://twitter.com/i/web/status/1352395636369313798
Jan 21
DIY Drones via Twitter
Using ArduRover with an RTK GPS https://ift.tt/2N9I3RO
Jan 18
Jan 18
Jan 18
Jan 15
Jan 15
Jan 14
RT @Heavy02011: @diyrobocars : A Home-brew computer club* for Connected Autonomous Driving on Jan 23rd, 2021 https://www.meetup.com/Connected-Autonomous-Driving/events/275728684/ #Meetu…
Jan 14
Jan 14
RT @Heavy02011: ⁦@diyrobocars⁩ Autonomous Driving Assembly at #rC3. join us at https://rc3.world/rc3/assembly/diyrobocars-f1tenth/ ⁦@f1tenth⁩ ⁦@DAVGtech⁩ ⁦@DWalmroth⁩…
Jan 11
