  • Are you familiar with Google Sketchup?  There is a few Hawks in the 3d library.  You could explode the drawings and change for your use.
    There is also a real difference between the RQ-4A and B variants (block 20, 40 etc).  The B variant copy would probably be more stable due to added dihedral angle.  The more commonly copied RQ-4A has nearly none.  They both use the LRN-1015 airfoil through to the tip.3692240305?profile=original
    Not sure what the V-tail uses.
    • Wow! Thats just a thing of beauty! Talk about form meeting function. I could frame that and hang it on my wall.
  • I believe they are classified.
  • If you are looking to build an RC model, they would most likely be using a different cross section on the wing than the real plane to get better control for the scale change but otherwise you could alwasy just build your own off some 3 view drawings.
    But no I dont know of any good plans for that plane.
