Guys,
I am having some trouble figuring out if the sounds from my Pixhawk running the latest APM:Plane on it , indicate a problem. Everythign otherwise seems to work great on ground - though havent flown in air.
Heres the video :
https://www.youtube.com/watch?v=-fYUpJf8kxg
Its the last tone at the end that I cant figure out. Does that indicate an error ?
Thanks !
I am also worried about a tone I am getting on startup with my pixhawk. As soon as I power it up I get a high pitch tone which continues until the "start up ok" trill. It's really annoying and I can't find any info anywhere on how to stop it. Any ideas?
Thomas, My comment did not post completely, for some reason.
So when i power up i get the musical tone. and then after about 10 seconds i get a flat, long beep . This long beep is what i am curious about. Does it signal some kind of error ?
The yellow flashing light is understandable, as it would be due to failed GPS which is fine since I am indoors .
I want to fly this , but not confident till i figure out that long beep.
Thanks !
My PX4 gives the same pattern on boot up, a little trill of mixed tones followed in about 10 seconds by a long single note.
I've never investigated it but just took it as being a confirmation note that all is well and the board has booted successfully.
FYI the long note confirms that the board is armed:-)
@FPVGenie,
I am not hearing any audio in your video. Maybe its my computer.
However, after boot up and before there is a GPS 3D lock, the big led should be flashing blue, I believe, not yellow. The other leds look okay as far as I can tell.
TCIII ArduRover2 Developer
Thanks Thomas ,
The audio is there in the video .
