My drone flies well in stabilized mode but when in loiter it gets jerky and somewhat noisy. It still flies, but not like I would like. I have changed flight controllers, GPS's and motors not the Q-brain ESC. There is no issue until I go to loiter or RTL. It has to be a setting in Mission planner but I cant find the answer. when I remove the Tiger MN4110 370kv motors and put Turunigy 4425 390kv it flies perfect. The extra weight or something is making the set up not fly well.
Any suggestions are appriciated.
Rob
Tilt? I keep all my craft as close to defaults as humanly possible. 45 degrees has been perfect for me since I don't fly acro or race or anything. My T960 on 320kv motors and 15x4.5 props flies perfect on stock pids and settings and even in wind holds really well. I do find though that the bigger the frame, the larger the props, the more it does get "pushed" around by the wind and tends to have to work a bit harder to hold position in loiter.
I reset to default and started over. I changed the THR MID to 400, calibrated everything and it seems to fly good. I am thinking after an autotune it will be correct. Thanks again for the help. I would like to get your thoughts on the tilt for windy conditions. what would be a good setting for higher winds?
Rob Summers said:
ok ill try that in the am and let you know. thanks again....
Craig said:
then make sure to set THR_MID to 400
Rob Summers said:
I would guess 40% throttle
Craig said:
That is correct but i did do and auto tune but I made no specific changes for motors.. I have built 7 or 8 of these then decided to improve my wind performance with motors. In hind sight I needed to work on tilt angle and other tuning areas.
Mark Brummett said:
how "much" below 50% in stabilize? Seems Mark already answered what I was eluding to. Set your Throttle Mid Point in Mission planner to your stab hover % and it will help but also as Mark says you do need to do a full calibration and possibly a compassmot.
Rob Summers said:
THR_MID sets the midpoint in Stabilize. Loiter will ALWAYS be around 50 percent because it uses the altimeter to find the hover. Stabilize doesn't. You need note where on the throttle throw in percentage that the craft hovers in stablize mode. Set THR_MID to that number (I can't remember, it might be percentage * 10 - example, if it takes 30 percent throttle to hover in stabilize then set THR_MID to 300). But the oscillation to me sounds more like you changing motors on a frame without retuning. You noted that when you changed back to a specific motor, that behavior stopped.
1
2
of 2 Next
