Hi there!
Legitimate 3DR Pixhawk owner.
I started my first Pixhawk build 3 days ago with SimonK Afros. No go. Sync issues, even after FW update.
Bought and overnighted some EMAX 60a ESCS. Apparently EMAX also has compatibility issues with Pixhawk.
No go, for whatever reason, and the dev ticket to fix this issue is apparently closed with no solution.
What's a not garbage 40-60a ESC that isn't terrible that I can go spend even more hundreds of dollars on that is guaranteed to work with the Pixhawk?
Rules:
No SimonK, because that firmware isn't compatible.
No EMAX because that hardware isn't compatible.
I hope this could end up being an actual, no BS compatible ESC reference for others that have less time or cash they want to waste
      • I agree.  Unfortunately, we can't fix hardware problems or sync problems in flight controller software.  This needs to be fixed by the ESC manufacturers.  The best we could do would be to add a low-pass filter to the PWM outputs, but then that would defeat the purpose of using the high-response ESC firmwares anyway.
      • Why sir, I like the cut of your jib!
  • Hi, I had a problem with my Jdrones 5010 motors on Afros. The Emax 4 in 1 goes into fault mode, because Pixhawk put out 0 pwm before arming, so that also went in the bin.
    After contacting Jdrones, I was adviced to try Hobbywing Xrotor esc.  They work perfectly, and I have not touched a setting.
    The are also quite inexpensive.
    Lars
    I'm working on a fix for the emax 4 in 1 esc using an op-amp. I won't go too far into the electronic theory but it should fix the issues. I will post when complete. Till then the Quattro 4 in 1 works very well.
  • I use KDE UAS 55A+ with KDE 4014XF (380kv) + 18" props. It works great with Pixhawk.
    • Is it a true OPTO?
      • It is OPTO. What do you mean by "true opto"?
        Please find link below:
        KDE 55A+
        • And FWIW, the HW Xrotor ESC's are not true opto, but they still work well.
        • Check for continuity between the ESC negative battery lead, and the negative signal wire. If there is continuity, it's not true opto.
          Cheap Chinese ESC manufacturers have taken to using the term "opto" to signify they do not have a BEC circuit.  But true opto means that there is an optical decoupler between the ESC signal and power sections.
        • true OPTO meaning it uses a real optocoupler between the MCU and the signal wire, eliminating interference
