Our next Virtual Race will be on June 4th:
https://www.meetup.com/DIYRobocars/events/285787423?utm_medium=referral&utm_campaign=share-btn_savedevents_share_modal&utm_source=link
RT @SmallpixelCar: Test my car. RTK GPS worked great. Thanks @emlid for their support. https://t.co/EkQ6qmjmWR
RT @chr1sa: @kane That's @diydrones circa 2009. Still have a box of those Canon cameras that we used to strap into planes, just like this.…
RT @chr1sa: Our next @diyrobocars race is going to be outside at a real RC racetrack in Fremont on May 28. Fully autonomous racing, head-to…
RT @f1tenth: Our Spring 2022 F1TENTH course @PennEngineers is coming to an end with a head-to-head race as a big finale. So proud of our st…
RT @DanielChiaJH: I wrote a thing! Throughout the development of my @diyrobocars car I've been using @foxglovedev Studio to visualize and d…
RT @SmallpixelCar: My new car for high speed. Low body, everything ( @NVIDIAEmbedded Jetson Xavier NX, @emlid RTK GPS, IMC) under the deck…
RT @f1tenth: F1TENTH Race training setup @PennEngineers for our upcoming ICRA2022 @ieee_ras_icra competition. @OpenRoboticsOrg @IndyAChalle…
RT @fatcatFABLAB: Proud to be hosting a restarted DIY Robocars NYC Meetup April 26. Come by if you want to talk about and race self-driving…
Was a solution found for this?
I'm having a similar problem. All-In-One Calibration works perfectly (All motors start together, nice linear throttle, Max/Min Throttle PWM is good), but when I power off and on again the escs are not sync'd and wants to take off at the slightest amount of throttle (<15%).
I have also done one-by-one esc calibration which works but again, once the APM is powered off and on again the above conditions appear again.
I have adjusted Throttle_Min to the lowest value. The quad is flyable but Loiter and Alt Hold make it act like a bull on steroids. I've done some PID tuning to make it less aggressive which helped, but I still come back to the ESC calibration. I get all the right beeps and good throttle during the Calibration but on cycling power it doesn't seem to hold the Max/Min throttle values to the ESCs. Its like it thinks throttle starts at 50%.
I have tried this using SBUS-CPPM and individual Channel cables. Same results.
Taranis Plus w/ X8R using SBUS-CPPM encoder
3DR APM 2.6 (quad v3.2)
Tarot 650 Frame
RC Timer 5010 530Kv motors
RC Timer 45A SimonK Escs
14x5.5 Props
Same here. 4-in-1 Esc calibration won't retain. While in calibration mode, and right after you lift the stick to test it, those motors roar. But power it down, and back up after 30 seconds, you lift the throttle a bit and the motors barely idle.... and not change in speed when moving the stick upwards for the next 2/3rd of the way.
Pixhawk
Iris
