Hi Folks,
I've read lost about FBW on the wiki, notably this article (https://code.google.com/p/ardupilot-mega/wiki/FlightModesFlyByWire), which describes the mode as attitude control with manual throttle.
I'm using APM 2.4 and my FBW A runs my prop at 45% or so. There are several places in the documentation where this is contradicted.
What's going on here? Is that prop supposed to spin or not? I'd prefer it not to, honestly. 45% is a big waste of battery when you're already at altitude and you had some gliding in mind.
Is anyone else seeing this?
spag
I should mention a recent breakthrough on this issue--I reloaded the firmware to the board once again, with the same param file and FBW_A and Stabilize worked as described. Not sure how that works... but it did. I had the new incarnation of the plane in the air yesterday and it does what it should now. Jack, try pushing the firmware to the board again... worked for me somehow.
