Not many people know but we have an piece of open source software for controlling an Antenna Tracker. It's been built by Tridge (Arduplane lead developer) for use in the outback challenge.
Sadly we have no documentation and, as far as I know, nobody except Tridge has used it. Still given Tridge's track record on building great software I suspect it works well and if it doesn't, I'm sure we can fix it. So to not let this piece of code go to waste, I'd like some help from people who are interested to give it a try and help me figure out how it works.
Here's the little that I know:
- It runs on any of our supported board (APM1, APM2, PX4, Pixhawk, Flymaple and perhaps VRBrain)
- For APM1/APM2 users building the code is as easy as opening our hacked ArduinoIDE and selecting File > SketchBook > Tools > AntennaTracker and then building in the normal way. For PX4/Pixhawk, our autobuilder doesn't automatically build a binary but I can provide one if people are interested.
- It can control a Pan and Tilt gimbal like this or this found on servocity.com.
- It may or may not require a GPS
- It must somehow receive vehicle position updates from the ground station which has the telemetry radio that is connected to the vehicle. Maybe through a USB cable. Tridge probably uses the python ground station, MAVProxy, to passthrough the vehicle position data to the AT but perhaps we can get MichaelO to build out a similar feature in Mission Planner.
- I imagine this antenna tracker could also be used to keep a camera focused on the vehicle which might be good for easing the burden on creating videos of our vehicles.
So if you want to give it a try please do and stick any findings, questions or issues below. Alternatively Issues can go into the issues list.
I'll start sticking things into the wiki as they become clear.
I¨ve set up Pixhawk as a antenna tracker and use the ReadyMade RC¨s wooden tracker with two servos working great when testing with no power from the Pixhawk. I have a TGY Plush 30A ESC to power the servorail on the Pixhawk, but the servos barely moves when tested from Mission Planner. I use this servos:
https://hobbyking.com/en_us/turnigy-tgy-sm-8166r-360-analog-metal-g...
http://www.ebay.com/itm/Rage-RC-S104-16-6VM-Standard-Size-Metal-Gea...
I just meassured the power from the ESC to be 4.95 volts.
Should I buy a BEC that uses 5 and 6 volts and power the servos from this and only signal from the PH?
Jorn
Randy looks to be busy with the Copter v3.4 release.
What happened to Randy?
Is he working on V1.1?
I have never built the code so hopefully someone else will post a solution for you.
I'm trying to build it with PX4 Toolchain but with no success yet.
When I hit "make configure" in PX4 console I get: "make configure is no longer required"
OK, but there is no config.mk created then..
then I hit "make apm1" or "make apm2" and get error:
../mk/targets.mk:13: *** apm1 is deprecated on master branch; use master-AVR. Stop.
Have no idea how to fix it.
In fact I didn't do clone from github, just copied zip file with ardupilot sources from github and then unziped to local drive. Could it be the problem?
Thanks Greg a lot. I really appreciate it.
Anyway I'm going to study how to open cpp project in Arduino, because afaik it only accepts ino or pde files :-)
I found the commit for v0.8.0 in github. Hopefully, it will help.
Tracker: version to 0.8 and release notes
It didn't load pictures with error messages from MP. Anyway the texts are :
The hex file did no contain an end flag. aborting
next dialog is:
Failed to read firmware.hex:No end flag in file
and last :
Error uploading firmware
If anybody here has snapshot from GIT of source files of AT 0.8.0 please PM me. I will try to compile it by myself.
Please help,
I was trying to upload FW 0.8.0 in MP but without success. When I hit "Load custtom firmware", first option which contains also AT 0.8.0, downloading start but after a while I get error message:
Seems to me like the file is not already there in repo. Is there anybody here listening who can build it again for me?
For APM1 and APM2?
7
8
9
10
11
of 104 Next
