Final touch set-up hepl!
Well, I'm finishing putting together my arducopter. I have followed everything as per wiki. connection and calibration thru CLI.Here is my calibration set-upFirmware 1.54Magnetom. offsets ((x,y,z): -108.50, -39.00, -17.00Accel offsets (x,y,z): 2058, 2050, 2057Min Throttle:1099Magnetometer 1-ena/0-dis: 1Camera mode:0Flught orientation: + modeHere is what I need help with.I tested the motors in CLI and all of them are working left, right, front and rear when I move my JR 9303 control right stick. I'm able to arm the motors, moving the right stick to the right bottom and disarm it moving it to the left bottom. So now I want to begin to use the throttle stick to start moving the motors after I arm it, watching the green LEDS blinking.What should I do now?I have JR 9303 with AR7000
    Set your minimum throttle in the CLI, and calibrate your ESCs one at a time by connecting them direct to your radio on chanel three and following your manufacturers instructions.
    Put it all back, and then once you "arm" the throttle your motors will all spin with a tiny bit of throttle or none at all.
    Buzz
